Old 02-06-2024, 07:51 AM   #1
komichal
Torque wrench for valve cover?
Hi guys,
I need to change gasket under valve cover (small oil leak into one plug chamber) of my 2SZ-FE engine.
I did not find torque for exactly this engine but most small Toyota engines use 10-12 Nm for valve cover bolts so I guess that should be OK for me too.
However - I do not have torque wrench for such a small torque.
So the question is - how critical the exact torque for the cover is? My wild guess is that it is "not critical" and sensitive tighting by hand should suffice. It is not the head (where torque wrench would be a must). Are you with me on this?
Or is the material extremely problematic and I should really get a torque wrench?
Also - how about the order of tightening, is there any specific rule? For heads we go inside out in circles, but the valve cover is simply just a bunch of bolts around. Should I go zigzag or...?
Thanks for sharing anything on that.
Old 02-07-2024, 06:02 AM   #2
komichal
OK found the torque and bolt tightening order for 2SZ-FE:
Digital Torque Wrench At Harbour Freight bronsin DIY / Maintenance / Service 6 03-15-2015 10:52 AM
Torque wrench - looking for a particular type Yarflana DIY / Maintenance / Service 10 04-05-2013 01:09 AM
Torque wrench on lugs is critical on the Yaris A-Dingo-Ate-My-Baby Wheels, Tires and Suspension Forum sponsored by The Tire Rack 3 12-13-2011 07:33 AM
Clazzio Seat Cover DIY Install PETERPOOP DIY / Maintenance / Service 31 09-10-2010 04:30 PM
Torque Wrench rossman DIY / Maintenance / Service 21 11-24-2009 02:02 PM
