Old 03-20-2024, 08:34 PM   #1
RMcG
Drives: Yaris manufactured after 2007
Questions about doing my own front brakes
Hello Forum members,
I always appreciate your advice. I have never done my own brakes. I have a 2008 Yaris 3 door Hatchback base model. It had about 120,000 miles on it last October and I took it in to get a free brake inspection from a local chain here in the US Pacific NW that has a good reputation for skill and honesty.
They said I should get new front brakes in a couple of months (by January 1, 2024), because I was down to about 4 mm on the front brake pads (the rear drum brakes are OK). The estimate to replace the front brakes was broken down as follows: $160 for labor, $191 for 2 “new” remanufactured Raybestos calipers (RC 12024 & RC 12023), $138 for two new brake rotors, $49 tax. Total cost to do front brakes about $537; significantly more than I thought it would be.
My thoughts on the estimate: This is the first time since I bought the car new in 2008 that I have needed brakes. I only drive the car less than 9,000 miles per year, and 4 mm is still pretty good, so I still haven’t replaced the brake pads. And there has not yet been any squeeling from the brake pad wear indicators – I know what this sounds like from other cars I have driven in the past.
I have never replaced my own brakes, but I like to do things myself if it is possible and realistic. And I was thinking that I might be able to just replace the front brake pads myself: youtube videos showing how to replace the front brake pads make it look pretty easy. I wasn’t thinking I would need new calipers: I have only driven the car in areas of the country where they do not use road salt that could corrode calipers. I was not even sure I needed new rotors: the rotors look pretty smooth looking through the wheels, although I have not actually looked at the entire rotors with the wheels removed or measured the width of the rotors with a ruler or micrometer.
It looks like I can get a caliper, rotor & brake pad kit for about $212 + $54 for shipping and tax from Rock Auto; total cost about $266 (prices from Amazon for the same type of kit appear about the same). So if I were to do the entire job (calipers, pads & rotors) myself I would save about $537-$266 = $271.
I think I have and can borrow the tools I need to do the job myself (wrenches, jacks, axle safety stands, chocks, etc). The only thing I might have to buy is the piston wind back tool, cost about $13 to $25 from Amazon.
QUESTIONS:
How can I tell if I really need new calipers?
Does anybody have any suggestions about determining if I really need new rotors?
Any other comments or advice will be appreciated.
Thank you,
R.
RMcG is offline   Reply With Quote
brake, front, replacement
Front brakes not braking evenly stuf99 DIY / Maintenance / Service 3 05-11-2021 02:20 PM
2007 sedan front brakes job questions maui DIY / Maintenance / Service 11 09-28-2014 09:18 PM
Front brakes lasted 168000kms jambo101 DIY / Maintenance / Service 7 07-24-2014 11:30 PM
Front brake caliper pins DarkSkyGhost DIY / Maintenance / Service 7 06-10-2014 09:05 AM
general service of brakes TriumphAnt DIY / Maintenance / Service 10 08-07-2010 03:20 PM
