Old 05-28-2024, 08:46 PM   #1
mirageman
Drives: 2009 yaris
Manual transmission rattle
Hello all. 2009 Yaris 5-speed. 322k miles. Yes. 48+mpg, burns a quart of oil every 8k miles, so I want to keep it. Rattles on acceleration 35-60mph. It is not a wheel bearing.
Long story short: There are threads on this topic here that seem to only say it needed a transmission. I was hoping someone knows what the actual issue was inside the trans so I might decide to dig in and do it myself.
Short story long: Past 2 weeks or so I've noticed a mild rattle after 35 mph up to like 65 after which general wind/window noise seems to muffle the sound. Happens only on acceleration. I was hoping it was just a wheel bearing but I did some testing today and determined it is my trans. I just did a trans fluid drain which was due, and got 2+quarts out, so no loss of fluid and very minor sparklies, which I expected as I have ground gears by accident several times over the years. I would expect much more if something was very bad based on the sound. I think the problem is in the differential. I jacked up the front passenger side off the floor, ebrake on, driver's front side and rear end on the floor. I put it in gear and went through the speed and heard the pronounced rattle. I left it in 5th gear, wife stepping on the gas and went to the wheel and heard no concerning noise at the spinning wheel. I DID hear the rattle in the center of the engine compartment in the back by the diff, though. I then got inside the car, stepped on the clutch and shut the engine off. I heard the rattle still, all the way as the wheel was winding down, so it is NOT the engine. I then put the passenger side on the floor, raised the driver's side and did the same and also found no bad noise at the wheel, but again heard the rattle in the center of the engine compartment in the rear by the diff. I did this standing in front of the car because I did not want to go under it (chicken). This shows either a differential problem or BOTH inner cv joints have decided to wear at the same time. I also noticed something that might be a clue. I have done hypermiling whatever since forever, where on long downhills I shut the engine off and put 'er in neutral. I would then use 5th or 4th and slowly release the clutch to start it up again when I have to. On the road, when engine off, in neutral, there is no rattle, but when I start to engage the clutch to restart, it IMMEDIATELY starts the rattle, even though the engine has not started yet. Note that this is different from wheel in the air testing as I have done today. I've already driven 1000 miles like this, but it was milder and I didn't know it was a trans issue... I thought it was just a wheel bearing going, hehe.... anyway it has gotten worse and I am scared to do any major roadtrips until this is fixed. So just simply wondering if anyone might know what exactly goes wrong in these manual transmissions. Differential bearing? Most likely I think. Thanks.
Last edited by mirageman; 05-28-2024 at 09:58 PM. Reason: specified "wheel" bearing.
mirageman is offline   Reply With Quote
Old 08-05-2024, 11:46 PM   #2
mirageman
Drives: 2009 yaris
Little bump here... also I haven't fixed it yet and it has been over 12k miles already. It started rattling on acceleration and like 2k miles later, it rattles on both acceleration and deceleration. The sound hasn't gotten worse in the past maybe 8k miles. I read a very similar thread on a Nissan forum, I think a Versa, the poster says he drove it all rattling like this for over 40k miles before he like junked the car or sold it. He didn't bother fixing it at all. Gave me courage to continue driving as is �� . I still get 47-49 mpg.
Old 08-06-2024, 07:03 PM   #3
ex-x-fire
Best answer if your Yaris manual trans is noisy then swap it out, they are not the most durable manual out there. I replaced one in a 08 Camary last year for noise issues.
Yaris 5 speed manual transmission ID dsmith5282 DIY / Maintenance / Service 2 12-13-2021 07:10 AM
Manual transmission fluid; use OEM? Black_griffin6 DIY / Maintenance / Service 20 04-19-2017 09:47 PM
Car will shift into gears (manual transmission) but won't move kustomrtr DIY / Maintenance / Service 4 04-11-2017 12:44 PM
Removal of manual transmission cable to get to reverse switch 7:34pm DIY / Maintenance / Service 2 02-02-2017 11:06 AM
REMOTE STARTER FOR MANUAL TRANSMISSION YARIS CAR ks25 Photo-Video-Media Gallery 1 07-01-2012 06:42 PM
