Old 06-26-2024, 10:43 AM   #1
k98shooter
Drives: 2012 Yaris Hatchback 3 door
Intake air temperature circuit input high
Hello everyone,
I am working on 2017 Yaris with 1 nz fe engine. Acquired the car from insurance auction, frontal collision. 81k miles on odometer. Pretty much everything is sorted out and the car runs fine, however CEL remains and the code refers to intake air temperature. Replaced entire air intake and intake manifold with throttle body, as they were damaged. New MAP sensor. Do you know if intake air temp sensor is integrated into same housing as MAP sensor? If so, what color wire supplies voltage to it? I understand this is different from ambient air temperature sensor that is behind bumper cover? Thanks a bunch!
k98shooter is offline   Reply With Quote
Old 06-27-2024, 07:16 AM   #2
komichal
I do not know this particular engine well but I always thought it uses MAF, not MAP.
I also know some engines use both MAP and MAF.
MAFs measure air temperature as well.
Old 06-27-2024, 06:13 PM   #3
kevinj93
kevinj93's Avatar
Drives: 2013 NCP130
Hopefully the details from the 2011 model are the same:-
Codes P0110, P0112 or P0113
The intake air temperature sensor is mounted in the mass air flow meter.
The wiring diagram shows it connected between pins 4 and 5 of connector B72 on the MAF, corresponding to pins 65 and 88 of connector B84 on the ECM.
The wire colours at the MAF should be pink for pin 4 and green for pin 5.
The resistance measured between these pins is dependent on air temperature, with higher resistance for lower temperatures. This could be around 1 - 2 ohms at 100 degrees F or 7000 to 10000 ohms at 32 degrees F.
Running on standard AU 14" steel wheels (14x5 rims, 175/70R14 tyres). Added reversing camera and touch screen radio, cruise control, 16" rear wiper blade, tow bar and dash cam.
kevinj93 is offline   Reply With Quote
Cold Air Intake... I PHANT0M I Performance Modifications 17 05-17-2012 08:57 PM
Just installed air intake on 1.5L! E3pO Performance Modifications 29 02-11-2012 09:19 PM
Cold Air Intake... I PHANT0M I General Yaris / Vitz Discussion 2 01-31-2012 02:22 PM
Ram Air Intake? fmicle Performance Modifications 6 11-20-2009 12:06 PM
High pitched whine using stock head unit / aux input? IsLNdbOi In Car Entertainment + Electronics (audio / video / alarm) 8 02-02-2007 12:49 PM
