Old 07-17-2024, 10:56 PM   #1
cedwards
Drives: 2007 Yaris Hatchback
Car Turns over but won't fully start after cruise control mod
I followed this guide exactly, but whenever I try to start the car it turns over, but will not fully start. Is there anything I can do?
2007 Toyota Yaris Hatchback.
cedwards is offline   Reply With Quote
Old 07-18-2024, 12:47 PM   #2
Neinris
I did this mod many many years ago and have no problem. Do you have a manual or automatic? what happens if you keep your clutch/brake depressed?
Old 07-18-2024, 02:19 PM   #3
cedwards
I have an automatic hatchback, and it still doesn't turn on even with the brake fully depressed. thanks so much for your help. My uncle thought I might have bent a pin in the ECU when I was doing that part, or not seated something fully.
Old 07-19-2024, 12:14 PM   #4
Neinris
I thought maybe it might have been a bad switch. But yeah, check for bad pin(s).
Old 07-19-2024, 01:19 PM   #5
bairjo
This is how I did it in 2010 and it works fine. Hope the video uploaded and it works as well.
https://youtu.be/sF3qkUcfAqE
Old 07-23-2024, 06:55 PM   #6
bairjo
Well if I knew this guy wasn't going to respond with a third post. I wouldn't of bothered to upload my video to YouTube to help him out. Ill take it back down now.
Old 08-04-2024, 02:56 PM   #7
cedwards
Sorry. In the 2009 and newer models the cable was just run for you. I ended up buying this from eBay. https://www.ebay.com/itm/19252327533...mis&media=COPY And it’s working really well. Thanks for uploading the video though
Old 08-06-2024, 10:47 PM   #8
KermitAUS
Drives: Yaris 2009
Is there a video or instructions on how to do this cheaply for a 2009 3 door manual?
KermitAUS is offline   Reply With Quote
Yaris won't start properly/reliably lith89 DIY / Maintenance / Service 10 11-21-2016 01:54 AM
Changed Spark Plugs and Now Car Won't Start VegeLasagna DIY / Maintenance / Service 20 06-24-2016 10:36 PM
Grrrrr! Cruise control....MPG wrecker Gogogordy Fuel Economy Forum 8 09-16-2012 05:00 PM
Car wont start - help! tamo300 General Yaris / Vitz Discussion 14 03-23-2010 10:44 PM
New car shopping - long post littlecarlove General Yaris / Vitz Discussion 19 11-01-2006 10:58 PM
