Old 08-07-2024, 08:36 AM   #1
Mohiuddin789
Mohiuddin789's Avatar
Drives: Toyota Vitz 2013 1KR-FE
Vitz 2013 - 1KR-FE jerking/misfiring
Hello Everyone,
I have a Vitz 2013 with a 1kr-fe engine.
There was a small hole in the throttle body butterfly, which was then filled with glue; according to the mechanic, this gives extra air, which is not the standard way. That alteration was before I purchased it.
After purchasing it, I went to tune it. I changed the spark plugs, fuel Pump(50psi) and filter, CVT oil(Toyota cvtf-fe) and filter, engine oil and filter, and air filter.
I checked the ECU on the software, and no error was found. The mechanic did all calibrations, especially oil pressure for the CVT.
My car started jerking or misfiring at a low speed. When I pressed the gas pedal slightly, the car jerked, and it continued until it reached a maximum speed of 50 km.
When I press the gas harder there is no missing.
When I leave the peddle and push break, I again feel a minor jerk, which is negligible.
I checked it in all gear D,B, and S.
The ignition coils are in good condition. The fuel average is above 13 in the city, which is fine. The car runs well, with no engine codes or mechanical work—just the jerks.
Mohiuddin789 is offline   Reply With Quote
Old 08-14-2024, 04:10 PM   #2
Mohiuddin789
Please check the data list of my car checked on techstream 18.
https://postimg.cc/gallery/VvZbgC5
Old 08-18-2024, 10:08 AM   #3
Mohiuddin789
I checked the coils, fuel filter, pump, plugs, throttle body, MAF sensor, cleared manifold, and EGR, and the issue persists.
I observed that when I drive on an incline on a road, it jerks, but when I drive on a decline, it does not jerk. Also, when pressing the gas, the car revs more, but the speed does not go as fast as it should.
I purchased Techstream and mini VCI; there is no error appearing in the system. Live data is also good.
Old 09-03-2024, 03:17 PM   #4
Mohiuddin789
Is there anyone ?????
1kr-fe, cvt, jerks, missing
2013 Vitz Head Unit replacement daveyw In Car Entertainment + Electronics (audio / video / alarm) 0 02-27-2019 04:16 AM
2010 Vitz RS Modellista Completed Car Vitz Rs Modellista Photo-Video-Media Gallery 38 11-18-2014 12:25 PM
A German Yaris/Vitz/Echo ;) we-to-11 Photo-Video-Media Gallery 5 06-27-2007 08:26 PM
