Old 08-16-2024, 12:55 AM   #1
Turbiini
Drives: 1983 carina 2NZ-FTE
custom intake to 2nz
Some little parts still not fabricated, but intake is now ready.
Turbiini is offline   Reply With Quote
Old 08-17-2024, 08:45 AM   #2
Turbiini
Old 08-18-2024, 04:34 AM   #3
Turbiini
Everything is now working. Max maf values is now 73g/s with stock intake 65g/s. So about 10% more horsepower. no dtc put idle is litle high about 1000rpm. Car now report lot better fuel mileage, might be false reading.
Old 09-05-2024, 05:31 PM   #4
IndestructibleYaris
How did you determine the sizes for the runners and plenum and throttle body? I have a lot of questions and want answers! Looks great for homemade. Why is the flange an inch or two (25-50mm) thick?
IndestructibleYaris is offline   Reply With Quote
Old 09-06-2024, 10:26 AM   #5
Turbiini
Mainly i use materials that i found in scrap pile. but also thick flange prevents warping when welding, and is easy to make smooth transient from runner to intake port. runner is litle bigger than port after it has been crush to oval shape. runner length is shortest i can make without moving dipstick, i have try various lengths on my race car and seems to be that 2NZ like short runner, when max power is about 7000rpm range. plenum and throttle bodysize are big so they don't make any limitation, in full throttle its act like 4 intake trumpet. Part throttle things i don't care, this was only test what oem ecu reacts for it. i will later modify intake to fit rwd install and install it to my 2NZ swapped 66 corona
Old 10-15-2024, 07:13 AM   #6
Compeer
Drives: NCP90 TRD Yaris Manual
Originally Posted by Turbiini View Post
Beautiful build bro about to mod a honda one myself. How did she change performance? and how does the stock ecu like it?
Compeer is offline   Reply With Quote
Old 10-20-2024, 01:44 AM   #7
Turbiini
stock ecu works fine no dtc and every obd test pass. some ecu versions may be different results. This is euro3 emission manual trans version. Little more power on high revs under 4000 may lost some.
Problem for testing is there is some wrong with engine, it has dear spot on power output 4500-5500rpm even with stock intake. i thing it may be some mechanical noise for badly maintain high mileage engine. knock sensor hears piston slap or something an take ignition timing way down.
I have spare denso ecu with same connectors from my suzuki baleno. so install migrosquirt module in it. now engine works fine, now i also can remove maf or made bigger size maf tube.
Old 10-20-2024, 01:50 AM   #8
Turbiini
everything is still made to plug and play, and original parts are non modified, so its under half hour job to made it stock again.
Old 11-18-2024, 12:57 PM   #9
Compeer
Cool bro, how does it drive now? Opens up and accelerates faster you think?
Also come join the Yaris Nexus discord bit more active there https://discord.gg/j4299STP6x
tooter's manifold adventure... tooter Performance Modifications 1465 07-31-2014 08:11 PM
Custom Short Ram Air Intake Problem laxsaint99 DIY / Maintenance / Service 10 04-27-2011 01:28 AM
Custom Intake Manifold + Direct Port Nitrous blacksandiegovitz Performance Modifications 9 04-21-2010 07:05 PM
My Custom Intake RacerFreakXXX DIY / Maintenance / Service 7 12-21-2008 07:32 PM
