Old 09-08-2024, 10:33 AM   #1
Cognac
Drives: Yaris T-Sport '01
Crank no start 01 Yaris Ts
Hi all, been a while but hoping someone can help me dive into this issue.
Couple years back had a minor incident with a crash barrier that mangled my hood and radiator support. Chassis is fine and found replacements for the rest. While I had the space in the engine room I swapped the engine (1nz-fe) as mine was using buckets of oil.
After swapping engines gave the replacement a small service with oil, filter and plugs but engine ran very rough. Misfiring on cil 1. Switched coils from previous good running engine but problem remained.
Have a bluetooth obd scanner but didn’t get any codes or useful information so tried my luck with a vci plug. Never got it to work, but now some weird issues remain.(yes, lesson learned on copies)
- The cluster no longer displays the mileage unless the vci plug is in place
- Engine cranks fine but wont run at all anymore…
- After cranking the needles start dancing, only stopping after removing key
- key “on” position doesn’t show cel
So with the vci plug in place all looks fine, starts still but wont fire anyway.
Things I’ve tried:
- spray some brakecleaner to see if it runs, no luck
- checked all fuses, efi, am2, etc all good
- Have another Yaris, same year, engine etc and switched over ecu, key and cluster and was running fine so those components are good, thankfully ecu not fried
I’d say maybe I fried the obd port or something, but how does one check that? Cant seem to find wiring or pinout info for this ecu (Fujitsu 89661-52230 mt)
Cognac is offline   Reply With Quote
Old 09-09-2024, 02:11 AM   #2
komichal
I suppose the "new" engine came from a reliable source and was working just fine in the previous car. Using engine from some totaled car would be unwise.
I am just thinking if we need to locate a problem caused by engine swapping or if we can consider the swapping done fine and it is all about a problem that came inside the "new" engine.
yaris won't start, engine truns over but won't start. zara616 General Yaris / Vitz Discussion 16 09-05-2021 11:39 AM
2018 Yaris SE 5MT - T-Sport w/Valvematic! atomic_hoji Performance Modifications 130 02-23-2019 11:56 AM
Yaris Wont Start magnum555 DIY / Maintenance / Service 0 10-29-2017 05:30 AM
09 Yaris No Start dieselphreak DIY / Maintenance / Service 47 03-16-2015 11:36 AM
