Old 02-09-2025, 03:21 PM   #1
MikeYaris2011
Drives: 2011 Toyota Yaris
Struts
I have 2011 Yaris with 80k miles. A shop I've always trusted did a courtesy inspection and said front struts are so bad that one side could drop to the ground. I took it to another shop to do a complete vehicle inspection and they said everything is fine. Car doesn't bounce, rides fine, but very occasionally makes a slight click when turning. First shop said that was not sway bar links, but the struts.
MikeYaris2011 is offline   Reply With Quote
Old 02-15-2025, 06:05 PM   #2
CrimsonEclipse
Drives: .
The only your car could "drop to the ground" is if the spring broke.
The click is probably your tie rods, ball joints or, anti sway links.
Likely not a big deal unless you feel a control change or the steering does something weird going over a bump or in a turn.
CrimsonEclipse is offline   Reply With Quote
Old 02-16-2025, 09:31 AM   #3
bairjo
At 14 years old and 80,000 miles....your struts will need replaced very soon along with the sway bar links. Don't buy Moog sway bar links...they need lubed and there is almost no room to get a grease gun hose to the fittings. Buy sealed links.
Old 02-16-2025, 03:19 PM   #4
Liljoshyg
Drives: CLAPPED 2007 Yaris Sedan S
When it comes to replacing the struts, I have found that it is nearly impossible to find coils for the rear. Because the rear is a independent coil/shock setup.
Liljoshyg is offline   Reply With Quote
Old 02-17-2025, 12:44 AM   #5
bairjo
Rear coils at Toyotapartsdeal, PN 48231-52A51...$109 each. I have 252,000 miles on my Yaris and luckily never had to replace one of those. I have replaced the rear shocks and front struts twice.
Replacing front struts and rear shocks questions stiglitz Wheels, Tires and Suspension Forum sponsored by The Tire Rack 3 10-25-2022 02:44 PM
Struts 2007 Yaris cort21 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 5 02-10-2018 09:37 AM
09 Sedan Struts?? supmet Wheels, Tires and Suspension Forum sponsored by The Tire Rack 6 02-01-2010 01:20 PM
nf210s + trd struts?? static808 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 2 04-26-2007 11:38 AM
using the tops from stock struts with new trd struts? tekmoe Wheels, Tires and Suspension Forum sponsored by The Tire Rack 2 01-13-2007 11:58 AM
