Old 04-25-2025, 12:35 PM   #1
Alessandro
Drives: Toyota Yaris 1.4 D4.D 2013
Toyota Yaris 2013 1.4 D4-D - Dubious sound
I have a 2013 Toyota Yaris 1.4 D4-D, and I'm experiencing a humming or growling noise when the clutch pedal is not pressed. As soon as I press the clutch pedal, the noise disappears completely.
I had the same noise even before replacing the clutch, and I initially thought it was caused by a worn clutch. However, after having the clutch replaced recently, the noise is still present.
This makes me think the issue might be something else, like the dual-mass flywheel or maybe something in the gearbox — perhaps the input shaft bearing?
I've attached a video recording of the noise for reference. Any ideas or advice would be appreciated!
https://youtube.com/shorts/X2lXHH5Dyh0
Alessandro is offline   Reply With Quote
Old 04-27-2025, 11:30 PM   #2
komichal
I have something similar in 2007 Yaris.
I can hear it best when the car is idling in neutral, no pedal pressed.
It goes away once I nudge the gearstick towards 4 speed gear. Just a few milimeters.
I guess the gearbox is simply a bit worn out after 250 tkm. Oil changed regularly there, I am using original Toyota fluid.
2013 Toyota Yaris fog light HDTechVideo DIY / Maintenance / Service 8 10-29-2017 09:20 AM
2013 Black Toyota Yaris LE - 51000 odo tyta4lfe Cars for Sale by private party 1 08-23-2016 10:41 PM
Recent Toyota Yaris recall " electric steering" marcus DIY / Maintenance / Service 6 07-10-2013 02:30 PM
