Old 05-16-2025, 08:48 PM   #1
croustian68
Drives: Yaris LE 5dr 2016 AT Blue
Question MAF 1NZ-FE
i want to put a cone filter instead the kleenex oem one...
I have to bought a MAF adaptor to get solid mounting (cuz the oem is in rubber) so i have to take precise mesurement for buying the right adaptor
Im not 100% sure but it might be
31mm hole diametre for the sensor
55m center to center for the screw
and about 70mm diameter of the piping it self
Im i getting wrong about those spec
croustian68 is offline   Reply With Quote
Old 05-28-2025, 03:30 PM   #2
EPP
Drives: Yaris T-sport 2001
I 3d printed one for my T sport. post a pic of your engine bay and ill tell you if the model i made fits
EPP is offline   Reply With Quote
Troublesome MAF Sensor Circuit Low code woodamsc DIY / Maintenance / Service 4 10-13-2024 09:56 PM
Car will not idle after MAF relocation G.Chetcuti General Yaris / Vitz Discussion 13 02-19-2019 12:34 PM
New O-ring for MAF sensor komichal DIY / Maintenance / Service 3 10-23-2017 08:59 AM
Recommendations on Mass Air Flow Sensor (MAF) dyslexicanaboko Performance Modifications 11 02-08-2011 10:24 PM
