Old 06-06-2025, 09:37 PM   #1
Greenyaris2007
Drives: 2007 yaris
Coolant lead from floorboard behind drivers seat
2007 Yaris 4 door - Amazing car. Want to keep it going forever. Stumped on a coolant leak and wondering if anyone here has had the same issue?
220k miles - rust belt car. Coolant system all original other then water pumps and fluid.
First hot day in NJ this season and the car stalled at a traffic light. Coolant light flashing and check engine. Was able to get the car restarted and pulled off quickly so that I was not in an accident. Let the car sit in a lot for hours while it cooled off.
It took a gallon of coolant to get it to the top of the fill cap. Car started and made it home 2 miles. Went outside a little after to see where the coolant was leaking from. Found coolant at a constant fast drip coming from a floorboard body hole behind the driver side seat (on the undercarriage). Engine bay is pretty dry although there was some wet spots under the waterpump.
Engine oil checks out clean - no coolant mix.
Is this a heater core? Carpets are dry. No coolant smell inside the car.
Any help is greatly appreciated.
Greenyaris2007 is offline   Reply With Quote
Old 06-10-2025, 05:45 AM   #2
Billiam
Drives: '10 White Yaris 4D LB
I would think heater core. The coolant is probably finding its way under the carpet and collecting in the lowest area
If you want to enjoy your car, stay off of the internet.
DIY - Sparco Race Seat Install Idjiit DIY / Maintenance / Service 16 08-14-2017 09:15 PM
I have rip/tear on drivers seat going on. Killchain Cosmetic Modifications (Exterior/Interior) 2 09-10-2015 02:53 PM
Back Seat Removal... Idjiit DIY / Maintenance / Service 87 02-08-2015 12:07 PM
Drivers Side Seat Belt Won't Retract redyaris DIY / Maintenance / Service 8 08-07-2014 10:37 AM
Fabric Wear On Driver's Seat Darth Gilbert General Yaris / Vitz Discussion 18 04-28-2007 07:13 AM
