Old 07-09-2025, 10:38 PM   #1
nibiyabi
Drives: 2009 Yaris Sedan
Question Help identifying wire terminal pins from speaker to radio in 2009 sedan
Hello all, I've scoured all the top recommended sites for identifying wire terminal pins for many hours, and cannot find a perfect match for this connector. All speakers keep going out simultaneously from driving over bumps, sometimes for months at a time, so I finally took a look after they went out again. All the wires appear fine from the outside, so I just want to strip and re-terminate them all. Unfortunately, there is no reasonable way to re-use these terminal pins, so I need to identify them to buy replacements. I cannot find any documentation on here about these pins, and there are hundreds and hundreds if not thousands of terminal pins at this exact size out there, so if anyone knows which one this is, or can confirm that another similar pin will work, I would greatly appreciate it. Pictures attached. Thank you.
nibiyabi is offline   Reply With Quote
pins, radio problem, speakers, terminal, wire repair
Anyone else recently purchase a 2009 S Sedan 5-speed? Price? Hola_Jonathan New YARIS Purchase Forum 4 07-24-2009 03:03 AM
Need to replace front grill on 2009 Sedan Yari-Chan General Yaris / Vitz Discussion 10 05-22-2009 12:03 AM
