Old 07-09-2025, 11:22 PM   #1
Erikastout1
Drives: 2009 base sedan
2009 Yaris. Probable reverse polarity. Code 2118
Hi. My son has a 2009 Yaris sedan and a couple of days ago he tried jumping his car and I’m 99% sure he reversed the polarity. As a result, his car would not start, windows would not work, and he had the car towed home. My OBD2 scanner would not connect. Using my limited, limited skills, I changed a fusible link and ETCS fuse. The car now starts and idles, all windows work except driver’s window, and I connected the scanner and got p2118 code. Car will still not rev so I am assuming it is in limp mode.
So now, I’m stuck. What else should I check? I’m assuming the throttle body is ok, but a sensor attached to the throttle body? I am determined to fix this thing. Thanks.
Erikastout1 is offline   Reply With Quote
Rattle - Noise when Yaris put in Reverse Jungle Rot DIY / Maintenance / Service 14 08-27-2015 06:32 AM
Yaris 2009 vs 2012 steinway General Yaris / Vitz Discussion 5 09-27-2012 05:21 PM
Comparison Test: 2012 Toyota Yaris Vs. 2012 Toyota Prius c Yar Is Word Third Gen Yaris General Discussion 27 09-06-2012 11:37 PM
