Old 07-23-2025, 06:28 AM   #1
mhesky458
Drives: 2006 Yaris
2006 Yaris No Crank
Looking for advice — I’ve got a 2006 Toyota Yaris that won’t crank when I turn the key. Dash lights come on as normal, but when I press the clutch and turn the key to start, the dash lights go out and nothing happens. The car sat for about 2 months before I bought it and apparently it started fine before that however the battery is completely dead so I replaced it with a new one.
Here’s what I’ve tried and confirmed so far:
• Battery is brand new and fully charged
• Battery terminals are clean and tight
• Starter motor works — I applied 12V directly to the solenoid spade terminal and it cranked and engine started and ran fine
• Starter relay is good (tested it out of the car)
• Clutch pedal switch is working (I’m guessing as the dash lights only go out when pedal is pressed, so the circuit is activating or am I wrong )
• Ground from battery to engine is solid
• No voltage is reaching the solenoid signal wire when trying to crank
• Tested with multimeter on the solenoid’s spade connector — got 0V when someone turned the key
• Fuses are all good
Seems like the wire from the starter relay to the solenoid is either broken, corroded, or disconnected somewhere — just wondering if anyone else has had this issue or knows a common failure point?
If anyone’s got any other suggestions then let me know
Thanks
mhesky458 is offline   Reply With Quote
Do you like the 2012 restyle? hitmoninfinity Third Gen Yaris General Discussion 106 04-14-2016 08:08 PM
Yaris 2006 TRD yaris grill Yaris2006RS Cosmetic Modifications (Exterior/Interior) 0 01-14-2013 10:17 PM
06-10 Yaris Sedan cold air intake $40 kylevh21 Items for Sale by private party 2 04-01-2012 02:14 PM
2006 Yaris YRX stock seat ~ jaspie Willing to Buy by private party 0 01-13-2012 06:09 AM
