Old 08-16-2025, 02:58 PM   #1
albert1905
Drives: Yaris sedan 2012
2012 yaris sedan - cruise control light is coming on intermittently
The cruise control light are coming on intermittently.
The cruise control light is green.
I do not have cruise control. Nor have I installed an aftermarket CC.
The traction light came on briefly(at the same time) as the cruise control light. The traction light has not come back on since. But the CC continues to intermittently "flicker" on/off but its not constant. Not going around a corner or a certain speed.
I have tried cleaning the battery connections(there was build up).
But that did not fix issue.
Chatgpt thinks its a loose connection in the instrument cluster.
It is suggesting I re-seat the cluster.
anyone else ever had this CC light issue ?
albert1905 is offline   Reply With Quote
cruise control light, green instrument light, intermittent
DIY - 2009 Cruise Control for $10, without pulling the steering wheel and airbag CTScott DIY / Maintenance / Service 307 04-04-2023 04:43 AM
2009 Toyota Yaris OEM Cruise Control DIY BentSpace DIY / Maintenance / Service 7 04-16-2014 10:05 PM
2012 Fleet Sedan - Add keyless or cruise? gtrail DIY / Maintenance / Service 3 02-16-2014 01:03 AM
