Old 10-06-2025, 01:01 PM   #1
Alienated
Inner tie rod length question - MK3
I own a 2012 1.4diesel. Failed my country version of the MOT due to a bad inner tie rod.
So i went on a local parts site and ordered both outer and inner, however when i got the parts the inner one is way shorter than the OEM one.
But the parts supplier doesnt supply any other length. However there is another design available for the outer tie rod. The outer one on my car and the ones i ordered are a fairly short straight one. 84mm.
The other design is around twice the length. 173mm.
https://www.autodoc.co.no/febest/8560166
The old inner rod is somewhere between 350 and 400mm? But the new ones are 255mm. Can order the longer outer tie rod and combine with the 255mm inner?
Alienated is offline   Reply With Quote
Inner Tie Rod Question k98shooter DIY / Maintenance / Service 2 10-15-2022 06:19 PM
DND Tie Rod Shifter Sale fnkngrv Cosmetic Modifications (Exterior/Interior) 2 07-01-2015 03:53 PM
inner tie rod ends tmontague DIY / Maintenance / Service 0 04-25-2015 07:27 PM
Inner tie rod replacement - rack assembly? jwpaine DIY / Maintenance / Service 1 02-04-2015 07:22 PM
WTB Battery Tie Down Rod Altitude Willing to Buy by private party 3 01-07-2013 10:45 AM
