Old 06-21-2007, 03:29 PM   #1
dallas
Drives: Yaris Hatch /Landrover D2
Camber after spring install
Im looking at getting some lowering springs the Tein S tech's lower the car almost 2" has anyone done this drop and will the car still align to factory spec's? Ive used Eibach on other cars with good success, but on the Yaris it's only an inch drop! Please post your feedback on alignment after dropping your Yaris.
dallas is offline   Reply With Quote
Old 06-21-2007, 06:02 PM   #2
07typeS
07typeS's Avatar
Drives: 2007 White Toyota Yaris Type S
Send a message via AIM to 07typeS
1.2" thank you very much lol I like the trd springs, not too low but definately a decent drop, mine dropped more than 1.2 inches i think, and the ride is decent but when you start cornering it starts firming up....
TRD Springs w/ KYB Struts and Shocks, Custom CAI w/ K&N filter and pre filter wrap, Weapon R Header, Stock 15 inch alloys, Dezod Performance pads, Tanabe Front Strut Bar, 35% front door Tint and 20% Rear doors back Tint, De-Badged Ass, Custom painted flat black interior, Pioneer deh-p6700bt w/ IPOD hookup, Infinity components up front with custom mounted tweeter, Inifinity 6x9's out back, 1 12" kicker comp cvr........
07typeS is offline   Reply With Quote
Old 06-21-2007, 06:22 PM   #3
i'm using the S.Tech's. never needed an alignment. the car drives straight. i haven't noticed any camber changes either. then again, i'm also using the TRD Sportivo shocks, so i don't know if that makes a difference.
Old 06-21-2007, 07:15 PM   #4
The Stig
The Stig's Avatar
Drives: 07 LB MM 5spd, 99 M Coupe
same here just going to ride on the stock steelies for a little more to see if any strange tire wear or mystery rubs or what not....
The Stig is offline   Reply With Quote
Old 06-21-2007, 11:13 PM   #5
dallas
Thanks guys, check your tire for uneven wear, when you lower a car, After a drop you get negative camber which should accelerate tire wear. Unless you get an alignment. Has anyone gone for an alignment after the install. Do the teins bounce or pogo on the stock struts? They must be great on the sportivo's.
The Stig;100873]same here just going to ride on the stock steelies for a little more to see if any strange tire wear or mystery rubs or what not....[/QUOTE]
Old 06-22-2007, 02:33 AM   #6
slvryaris
slvryaris's Avatar
Drives: 2007 Yaris Sedan S
I am using Tanabe NF springs on mine and never had to align and I also went around the car and measured the height from the ground to the top of the wheel well and they are all exactly the same.
Old 06-22-2007, 02:57 AM   #7
HTM Yaris
resident senior
HTM Yaris's Avatar
Drives: 07 Yaris
I've changed suspension twice and both times it was within factory specs , not perfect mind you , but within specs .
srs / airbag light after head unit install? KwonSau In Car Entertainment + Electronics (audio / video / alarm) 7 12-24-2008 02:04 AM
TANABE DF210 Spring Install [pics] Chris07LB DIY / Maintenance / Service 148 07-16-2007 09:26 PM
Tanabe NF210 spring install help Jerkratt Performance Modifications 8 06-08-2007 10:13 AM
Front End Alignment after Spring Install? OK Yaris Wheels, Tires and Suspension Forum sponsored by The Tire Rack 12 08-26-2006 07:46 PM
Spring Install Price redglare45 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 1 06-30-2006 08:32 PM
