Old 06-23-2007, 09:20 PM   #1
my gauge install [updated pics 6/25]
I got the gauges in place, will post more pics when I finish the wiring this week. The cutting was scary and tedious, but I think worth the "OEM" look I wanted. These are Glowshift gauges - tach, voltmeter, and water temp:
Old 06-23-2007, 09:48 PM   #2
uncleyaris
nice job, I think the work was well worth it!
Old 06-23-2007, 09:50 PM   #3
nice, can't wait to see pics when it's wired up and lit up at night
Old 06-23-2007, 09:53 PM   #4
nickhjort
My R1 eats my Vitz!!
nickhjort's Avatar
Drives: '07 Vitz Lifty, Stick Shift
Hey with the Tach installed, how many RPM's are you getting? What are the idling RPM's? I installed an Evil 2 inch Tach in the same spot and it has a jumper on the back and I can either choose a 4 cyl., 6 cyl, or just use no jumper and all three give me different readings. I'm not sure which one's accurate. Let me know if you know :)
nickhjort is offline   Reply With Quote
Old 06-23-2007, 09:56 PM   #5
RPMs when the car is warmed up and idling should be 600-800RPM
Old 06-23-2007, 10:04 PM   #6
PetersRedYaris
PetersRedYaris's Avatar
Drives: 2005 Scion xB
Excellent work... I was thinking about doing the same with a tach only.
Old 06-23-2007, 10:04 PM   #7
uncleyaris
x2
Old 06-24-2007, 01:41 AM   #8
tk-421
tk-421's Avatar
Drives: 5D-07-LB
Great install!
How does the inside of the dash compartment look like now? Do the cables get in the way?
Old 06-24-2007, 01:55 AM   #9
Not wired up yet, but the last pic shows the gauges from the inside...I'll do a nice little harness so the glovebox can still be used..
Old 06-24-2007, 04:23 PM   #10
smokinyaris
smokinyaris's Avatar
Drives: bad boy
its really simple how u did urs i really like how etimago has his done and i think he used DEFI's for his BALLA STATUS..................
smokinyaris is offline   Reply With Quote
Old 06-24-2007, 05:31 PM   #11
jdium
Mr Attitude
jdium's Avatar
Drives: Blazing Blue 5 Spd
Nice. How does it look at night. And what is the glare like with no shade over the gauges?
jdium is offline   Reply With Quote
Old 06-24-2007, 08:50 PM   #12
cleong
Parallel Parking Pro
cleong's Avatar
Drives: Yaris 1.5 Manual
It would look tons better if it was angled toward the driver instead of sitting flat and flush against the glovebox cover.
Leong's NCP91 Toyota Yaris E
TRD Blue brake pads
DC Sports header
Old 06-24-2007, 09:24 PM   #13
not too much of an angle from where I sit behind the wheel, they are perfectly readable. Mounting at an angle would not be possible without some custom fabrication -- maybe later!
Old 06-26-2007, 10:55 AM   #14
ok so here's a few night shots, sorry for the crappy photography. I'll take some with a tripod and post up again. The needle is always red, the background color is changeable. There's a mode where it constantly dissolves from color to color, which will be cool for shows.
[Note: If you're going to race, don't buy these gauges, they are really cheap, the scale is completely useless and they are slow to respond. Autometer FTW. Just so you know.]
All red:
White background:
Blue background:
Old 06-26-2007, 11:00 AM   #15
Black Yaris
der Zeck
Black Yaris's Avatar
are those difficult to read at that angle? or would they be easier to read if they were straightened out?
Old 06-26-2007, 11:57 AM   #16
slothman86
slothman86's Avatar
Drives: 07 Yaris Liftback
how is the glare during the day?
Old 06-26-2007, 12:10 PM   #17
they are easy enough to read, how often do you need to know how many volts you're running, etc. No glare problems - I can only think of one angle where the sun might bounce off.
Yes, pointing them more horizontally would be better -- but it's a LOT more work, IMO. I'll get to that later, probably will require some fabrication to make it look pretty.
However, the range on these gauges is just plain stupid:
voltmeter: goes to 19 volts?
tach: goes to 11,000 rpm?
water temp: goes to 350 degrees?
The fact that only a portion of the gauge range is useful to me in this car is much more of an issue than the angle at which I mounted them.
Old 06-26-2007, 12:43 PM   #18
Chris07LB
Chris07LB's Avatar
Drives: Yaris Liftback
Perfect.
Summit, JEGS, etc. all sell little angled collar's you slip in before the gauge. They come in a few different size angles as well.
I think it looks perfect flush fit like that.
Tanabe Strut Tower Bar Install & Review [pics!] Chris07LB Wheels, Tires and Suspension Forum sponsored by The Tire Rack 57 04-07-2022 07:46 AM
Megan Header Install [pics] Chris07LB Performance Modifications 132 09-29-2010 03:41 PM
TANABE DF210 Spring Install [pics] Chris07LB DIY / Maintenance / Service 148 07-16-2007 09:26 PM
Gauge Pod for Liftback? eight_heads General Yaris / Vitz Discussion 2 06-07-2007 10:41 AM
RPM Gauge Install rwseattle DIY / Maintenance / Service 1 04-15-2007 12:23 PM
