Go Back   Toyota Yaris Forums - Ultimate Yaris Enthusiast Site > Second Generation Toyota Yaris Main Rooms > Regional Forums > NY / NJ/ CT / PA
Old 06-25-2007, 07:43 PM   #1
njyaris
YARIS NEWBIE
njyaris's Avatar
Drives: YARIS 07 LIFTBACK
Send a message via AIM to njyaris Send a message via Yahoo to njyaris
Rear Rattle
I have about 1K miles and as of today .. i have a rear rattle .. only occurs while I drive ..
I checked my exhaust .. the bushing that holds it to the chassis is there and all is connected .. kind of swings but .. when i swing it around manually .. no noise .. so i dont think that is causing the noise .. maybe its my license plate .. havent did anything there yet ..
anyone else have this experience?????
njyaris is offline   Reply With Quote
Old 06-25-2007, 07:58 PM   #2
brickhardmeat
Lonesome Cowboy
brickhardmeat's Avatar
Drives: 2007 WHITE HATCHBACK
I have lots of rattles back there. I think it is all that shit under the mat- spare, tire pressure gauge, nuts and stuff, those tubs and what not.
SPONSORED BY
Old 06-25-2007, 08:17 PM   #3
smokinyaris
smokinyaris's Avatar
Drives: bad boy
fuck it gut it out
smokinyaris is offline   Reply With Quote
Old 06-25-2007, 09:39 PM   #4
tk-421
tk-421's Avatar
Drives: 5D-07-LB
I kept hearing a rattle on the rear area for a while, then I realized that it comes from the seatbelt behind the driver's seat. Since then I've just tucked it better and the noise is barely noticeable now.
Turning up the stereo also helps.
Old 06-25-2007, 09:39 PM   #5
death is my gift
wacky broadway nightmare
death is my gift's Avatar
Drives: Willow is a '07 Red Yaris LB
Send a message via AIM to death is my gift Send a message via MSN to death is my gift Send a message via Yahoo to death is my gift
i had a biiiig problem like this and in my case it was the little cables with the caps that go on the rear window defroster. on the inside. kind of hard to explain.
rear defrost. inside. little cable that covers the heating element.
uh, whatever. i make my own sense. that's what it was for me. noisy rattling.
"it's always complicated and at some point someone has to draw the line and that is always going to be me. you get down on me for cutting myself off but in the end the slayer is always cut off" Buffy
death is my gift is offline   Reply With Quote
Old 06-25-2007, 09:43 PM   #6
brickhardmeat
Lonesome Cowboy
My seatbelt on the passengers side was rattling today. I tossed my deckand headrest. I think when I hit a bump those tubs or something in the tubs always bounces around and makes a bit of a thud. I think a good gutting and a can of fix a flat rolling around back there would solve the problem entirely. Except for the sound of that can of fix a flat rolling around and clanking into stuff.
SPONSORED BY
Old 06-25-2007, 10:05 PM   #7
njyaris
YARIS NEWBIE
njyaris's Avatar
Thanks i'll ck the seatbelts and the wire that connects to the defrost or better yet i'll just turn up my radio hahaha - i hope my yaris doesnt fall apart after I dump it with 18's
Old 06-25-2007, 10:15 PM   #8
brickhardmeat
Lonesome Cowboy
haha, get used to rattle if your going with that set up
your going to have rattles all over
SPONSORED BY
Old 06-26-2007, 09:25 AM   #9
kurokoma-kun
Drives: 2007 Yaris HB
I had a rattle coming from the plastic panel on hatch door. It's held on with little plastic pins, and one came out of its hole. Drove me insane, because every time I opened the hatch to find it, the little bugger rolled down inside the door! Finally removed the whole panel, put pins back in place, snapped it back on, presto, rattle fixed!
my yaris, kurokoma-kun
Rattle Causer in Rear? yaris-intuit DIY / Maintenance / Service 1 10-06-2006 06:56 PM
