Old 06-27-2007, 01:35 AM   #1
kei
Drives: 06 Yaris
How to adjust the angle HID
I just installed an aftermarket HID kit, but the beam is aiming too high, please if anyone know there's anything I can do the aim the beam lower?
kei is offline   Reply With Quote
Old 06-27-2007, 06:36 AM   #2
Violin
Violin's Avatar
Drives: 2007 Yaris LB Auto
You'll find white nylon adjusters behind the headlamp housing, just to the inside of the bulb on each side. Use a phillips head screwdriver.
You might want to count how many quarter turns from factory you go and record that somewhere so you can go back to factory settings in the future.
Old 06-27-2007, 07:00 AM   #3
Violin
Violin's Avatar
Old 06-27-2007, 02:09 PM   #4
reznunt
Hi!
reznunt's Avatar
Drives: EF Sedan
i don't know if pointing them down will help. the beam pattern sucks with these housings. i still get a lot of glare with them pointed all the way down to the point where it is almost unsafe to drive at high speeds on the freeway. i'm thinking about removing mine. good luck!
reznunt is offline   Reply With Quote
Old 06-27-2007, 04:16 PM   #5
kei
Drives: 06 Yaris
thanx, I will try adjusting first
Old 07-02-2007, 07:50 PM   #6
CaysE
That Focus Guy
CaysE's Avatar
Drives: 2004 Focus RSVT
I implore everyone to not install HID retrofits without using a projector housing. It is dangerous and annoying to other drivers in front of you.
http://www.danielsternlighting.com/t...nversions.html
CaysE is offline   Reply With Quote
Old 07-02-2007, 09:52 PM   #7
Violin
Violin's Avatar
I agree, but you're fighting a losing battle.
Old 07-03-2007, 12:33 AM   #8
CaysE
That Focus Guy
CaysE's Avatar
LOL I know it. It can't hurt to spread the word though.
Old 07-03-2007, 08:55 AM   #9
bearda
bearda's Avatar
Drives: 2006 Mazda3 Sedan
Absolutely. HID in reflector housings blind other drivers, and are unsafe.
That said, I've seen some pretty good results from aftermarket HIDs in OEM projector housings (where the OEM uses the same projector housing for their Halogens and HIDs).
bearda is offline   Reply With Quote
Is aftermarket HID kit legal (in NJ)? Jfoofoo Cosmetic Modifications (Exterior/Interior) 25 03-19-2009 02:05 PM
Closest to a HID kit? IsLNdbOi Cosmetic Modifications (Exterior/Interior) 62 03-18-2009 12:44 AM
DIY - HID Retrofit Violin DIY / Maintenance / Service 57 06-11-2007 06:17 PM
HID worth It? jamal1984 Performance Modifications 6 01-31-2007 03:42 AM
KLight HID Conversion Group Buy!! $165.00 shipped!! JRT lighting Sponsors Classifieds Area 4 11-20-2006 10:47 PM
