Old 07-06-2007, 03:25 AM   #1
eijikikimaru
Q(','Q)
eijikikimaru's Avatar
Drives: 3dr Meteroite
Post Ignition Key Light 56k unfriendly
Ignition Key Light
This is pretty fancy, looks to be just a plug-and-play installation, electrics-wise.
Like good old Thomas said, looks to be just a plug-and-play installation, electric wise. However I did this DIY for those of us that are pretty new to these types of electronic things. So if purchasing the Thailand GB ignition key light for the 3dr US LB then I'll show what I did. If this works for all others version great if not, I don't know how to help because I'm not a wiz at these type of things. I did this DIY because Team Thailand version a bit different and didn't explain a lot for us noobs ^_^
Tools
Phillip head screwdriver
Zip ties (provided in the package)
Step 1a:
Removing the 3 screws. There are two located behind the steering wheel and one below. Just turn your wheel and you'll be able to see the two up top. The one below will be located near the steering wheel height adjuster. (pictured with screws removed.
Left side
Right side
Underneath
Step 1b:
Pull this panel towards you and down. It's a fold down type and pops out when the right amount of force. Too much and you may bend/break it.
Closed/Opened
Step 1c:
Remove the (not so)secret compartment by first lifting the bottom two corners first to unlatch them and then slide the compartment down where then it lines up to two opening holes so you can pull out the whole secret compartment. To put back in reverse this step.
Close up of the bottom corners of the secret compartment. The side with the handle is facing the ground in this picture.
Close up on the top left side opening. Mirror image on the right side.
eijikikimaru is offline   Reply With Quote
Bulb Replacement Guide (led Sizes) theFEVA Cosmetic Modifications (Exterior/Interior) 113 02-28-2017 12:02 PM
Check engine light flashes during high reving AlphaFox DIY / Maintenance / Service 40 08-21-2007 01:43 PM
Reverse light vs Rear Fog light cooldavidko General Yaris / Vitz Discussion 3 01-03-2007 03:09 AM
"Airbag" center console light on 07 Sedan with side airbags atebit In Car Entertainment + Electronics (audio / video / alarm) 5 11-10-2006 06:10 PM
