Old 07-08-2007, 01:00 AM   #1
vacantj
Drives: Yaris 4Dr sedan
I'm thinking of getting the following wheels/rim size question?
I'm thinking of getting the following wheels/rims:
http://www.5zigenusa.com/english/pro...ne/lx9000.html
I'm thinking the 18' size but I'm concerned about the rubbing problems - I will lower the car so that was the other concern..
Thanks in advance!
vacantj is offline   Reply With Quote
Old 07-08-2007, 01:12 AM   #2
smokinyaris
smokinyaris's Avatar
Drives: bad boy
nice wheels you should be ok
smokinyaris is offline   Reply With Quote
Old 07-08-2007, 01:23 AM   #3
largeorangefont
Break'em off some.
largeorangefont's Avatar
Drives: 07 Yaris LB, 04 Cobra
You should be more concerned about the bolt pattern in the 18" size before you worry if they will rub or not.
Old 07-08-2007, 02:30 PM   #4
vacantj
thanks for the info..
Black Yaris (wheel and rim guy) said:
you can not get that wheel in an 18 our bolt pattern is 4x100
you can get it in a 17x7 with a +38 offset, run that with some 205/40R17's would be sharp and fit nice
Coolant Hose Size Question vasilios DIY / Maintenance / Service 2 06-27-2007 09:45 AM
Pocket size Yaris World ad. tacsnier General Yaris / Vitz Discussion 12 06-25-2007 12:57 PM
Tire Size Sabretooth Wheels, Tires and Suspension Forum sponsored by The Tire Rack 5 04-09-2007 12:28 PM
Rim size difference???? marcus General Yaris / Vitz Discussion 2 11-03-2006 03:20 PM
Bulb size (application) question. W.A.S.P Cosmetic Modifications (Exterior/Interior) 4 10-01-2006 02:21 AM
