Old 07-10-2007, 12:25 PM   #1
Astroman
Modded Moderator
Astroman's Avatar
Dealer said some BS...
I took my car in this morning to get it checked out. My A/C won't turn off after I turn it on, I had a problem with my driver side headlight, and I also noticed the egg smell from the exhaust. I just got the call back and they said it's "normal" for the A/C to stay on, since apparently the Yaris has a aftermarket air conditioning system. They said my headlight bulb is bad, which is BS because it's good. I just have to press on some VERY hot wires on the connector that is actually coming apart and it comes on. They said there was nothing I could do about my exhaust because there is no such TSB on the yaris hatch (BS, I have it!) and that I voided my warranty because I put on a non-toyota aftermarket exhaust. I have the TRD muffler, is this true?? I'm calling bullsh*t on them. I'm going back down there at 11am armed with proof I have a TRD muffler and the TSB. I'm also going to point out that the connector is actually melting. My aftermarket headlights are rated at 55/60, so there should not be any problems.
Old 07-10-2007, 12:36 PM   #2
Imagine
Insert sarcasm here.
Imagine's Avatar
Drives: 2009 Black Pearl Sand 3Dr
Take it to another Toyota dealer and get a second opinion.. They don't call them stealerships for nothing.
Imagine is offline   Reply With Quote
Old 07-10-2007, 12:41 PM   #3
Thirty-Nine
Small cars are a big deal
Thirty-Nine's Avatar
Man, reading this kind of stuff gets my blood boiling.
Your warranty is NOT voided because of ANY aftermarket exhaust. Unless they can prove your exhaust system CAUSED the "egg smell," then they need to fix it. By replacing your exhaust system you void the warranty on the factory exhaust system ONLY, not the whole car. If it's TRD that's even more frustrating.
Look up the Magnuson-Moss Warranty Act. Heck, I'll do it for you:
http://en.wikipedia.org/wiki/Magnuson-Moss_Warranty_Act
http://www.law.cornell.edu/uscode/ht..._15_10_50.html
http://www.ftc.gov/bcp/conline/pubs/.../warranty.shtm
Go in, be patient, polite, and surgical. Hand them the TSB. Ask to see that your warranty has been voided in writing -- they won't do it. It's a BS game some dealers play.
Man, this stuff makes me livid. Personally, I'd run screaming from that dealer.
Old 07-10-2007, 12:45 PM   #4
CaysE
That Focus Guy
CaysE's Avatar
Drives: 2004 Focus RSVT
I'm surprised to hear this about a Toyota dealer. They're usually pretty good. Don't even get me started about Ford.
CaysE is offline   Reply With Quote
Old 07-10-2007, 12:47 PM   #5
Yaris Revenge
GIGA...DRILL...BREAKER!!!
Yaris Revenge's Avatar
Drives: Lagann. ;P
Stick it to 'em 1st, though. Make 'em look like the idiots they are.
~YR
Be polite. Be professional. But have a plan to kill everyone you meet.
Yaris Revenge is offline   Reply With Quote
Old 07-10-2007, 12:59 PM   #6
Astroman
Modded Moderator
Astroman's Avatar
I'm going in armed with TSB's in hand, the JDM exhaust P/N, original USDM P/N and new P/N with pics. As far as the A/C, I can't believe they told me it was aftermarket! If that is the "norm" with a yaris, I want them to show that too me with the other Yaris on their lot. I talked to my salesman (he's been nice about everything at least) and he said it could be possible to swap my Yaris for one that wasn't involved in a accident without adding more debt. Yeah, I'm pretty upset. 45m till I go back in there.
Old 07-10-2007, 01:01 PM   #7
tacsniper
Drives: 07 White Yaris RS
go file a complaint with the HO in Toyota USA and get it fix somewhere else
tacsniper is offline   Reply With Quote
Old 07-10-2007, 01:01 PM   #8
Yaris Revenge
Drives: Lagann. ;P
What's the deal about "aftermarket" AC? Does that mean yours didn't originally have AC, and it was added later, or what? Even then, how does a switch turn it on but not off???
~YR
Old 07-10-2007, 01:09 PM   #9
Thirty-Nine
~YR
x2
Old 07-10-2007, 01:15 PM   #10
Astroman
Modded Moderator
Astroman's Avatar
~YR
It originally came with AC, in fact, AC is standard on the US Yaris! They said the clutch system is always on. But I can tell its not, because the car has less power in town with it on. Not only that, but they are going to charge me $75 for the diagnostic, since the car had been in a accident, even though the stuff I complained about is under warranty. Can they do that?
Old 07-10-2007, 02:56 PM   #11
PetersRedYaris
PetersRedYaris's Avatar
Drives: 2005 Scion xB
If you have aftermarket headlight bulbs, swap them back to the origionals before taking it in. A melted plug could be blamed on the bulbs or the car accident if it was damaged. Good luck.
Old 07-10-2007, 03:02 PM   #12
Meteorite Man
Passin' The Gas...Station
Meteorite Man's Avatar
Drives: Same As You But Different
Send a message via Yahoo to Meteorite Man
Depends on the how bad the accident was and where it happened on the car. You say headlights/headlight? Was the front end damaged? Maybe a wire is pinched where the sheetmetal was replaced/fixed? Did the headlight have problems PRIOR to the accident? First thing I would do if any of the answers are yes....call your insurance company if they payed for repairs. It's their $ (even if another insurance company paid, your insurance company pays for you and then goes after the responsible party) and they might be pretty interested in knowing that MAYBE the repair shop was at fault.
Not against you here and I see your legit bitch with the exhaust and possible a/c (might want to check that out along with the headlight / I'm asumming a harness could be pinched)
Good luck
Chuck
MY Gas Station Attendant Misses Me...
Chuck
Meteorite Man is offline   Reply With Quote
Old 07-10-2007, 03:06 PM   #13
Astroman
Modded Moderator
Astroman's Avatar
I had already taken it in this morning. I'll probably just replace the plug myself.
UPDATE ON SITUATION: I went into the service department at 11 armed with all the P/N's for the TRD exhaust & pics, all the TSB's and determination that I was right. BOY, did their tone change when I handed them the part numbers and TSB's! They took back that I had voided my warranty and ordered the new cat to take care of the sulfer smell. And the AC somehow magically works fine now , go figure. I guess the service guy told the wrench guy the wrong information about the AC so there was a misunderstanding there. I guess they thought I was talking about the compressor clutch, when I was talking about the on/off switch. They did say cheap gas can cause odor problems even with the replacement. Although how much merit that has because there are only 3 other liftbacks in town and I'm pretty sure none of the other owners have managed to hunt down the TSB's, and they all got theirs after I got mine. They even dropped the BS $75 diag. fee. Which they should have anyway, all my problems were under warranty anyhow. They made no mention of my NST pulley or the lines I ran for the power inverter which is good. Thanks for all the back-up guys, I really appreciated it! Gave me some extra confidence going in there!
Old 07-10-2007, 03:13 PM   #14
Astroman
Modded Moderator
Astroman's Avatar
Good luck
Chuck
This was what she looked like after the accident. I had no problems with the headlight before the accident and I had aftermarket bulbs. It doesn't seem to be a pinched wire because if I press on the back of the connector the headlight comes on and stays on until I shut the car off. It is super hot though even running stock wattage, and it looks like the connector is actually melting. I will try to run out and get a picture, it explains it a lot better.
Old 07-10-2007, 03:40 PM   #15
Thirty-Nine
Woo hoo! Glad it worked out in your favor! Well played!
I will say, I really pitty people that aren't well informed that get taken by $tealerships, because you know it happens all the time. It's also very hard to find a really good dealership. When I do, I always recommend them.
Old 07-10-2007, 03:42 PM   #16
Astroman
Modded Moderator
Astroman's Avatar
Here are the pictures of the light socket. Don't know how they could say it was the bulb.
Old 07-10-2007, 03:48 PM   #17
good job on making them feel dumb. props to ya.
Old 07-27-2007, 01:34 PM   #18
Astroman
Modded Moderator
Astroman's Avatar
UPDATE: Over my vacation in CA simply pushing on the back of the bulb socket didn't make the light work anymore. I removed the bulb and socket and the plug had melted and was burnt up pretty bad. The horz. prong on the H4 bulb was loose, and after wiring on a new socket (which was almost impossible to find in Visalia) I hooked up the aftermarket H4 bulb and removed it seconds later. It had already started to melt the new socket so I tossed it and put in my stock bulb so now I have one super white bulb and one yellow . I wish I had saved the old socket to show everyone. No more will I purchase bulbs from ebay, even ones rated for stock wattage. Anyone have some good (name brand) reccomendations? I have tried buying from retail stores before but none had the bright white look I want. Also Wednesday I had my stinky CAT replaced. No more smell and the dealer washed all 2,600 miles worth of road grime, dirt & bugs I had massacared along the way.
Did you special order your Yaris or buy it from dealer stock? gabagooo General Yaris / Vitz Discussion 46 02-01-2010 01:40 AM
Regular car wash, or Dealer car wash? Buckethead Wash, Wax, Detailing, Exterior Repairs 49 07-21-2007 12:46 PM
dealer is telling me no power option avail in my area twixt New YARIS Purchase Forum 56 06-15-2007 12:10 PM
Dealer being a pain...HELP KittenRD New YARIS Purchase Forum 23 05-01-2007 10:38 PM
Nightmare at the dealer Kitt Central and South America 4 01-16-2007 07:02 PM
