Old 07-14-2007, 03:36 AM   #1
rage2
Drives: 07 Black Yaris 5D
Cool DIY: JDM RS Tail Light Installation
I searched and couldn't find an install guide for these things, so I decided to make one myself. I'm in IT, so when it comes to installing stuff, I suck. I can build a secure multi-site VPN, but I can't change my own oil. This install is mega easy... was going to get my friend to help me with but I was impatient.
Stuff you'll need:
JDM RS Tail Lights (duh!)
2 x JDM Wiring Connector Part #82824-52050
10mm wrench
Flathead screwdriver
Small allen key.
First step is to open the trunk, and get access to the tail lamps. Using your flat head screwdriver, carefully pry the top of this cover off:
This exposes the tail lights assembly:
Using the wrench, remove the 2 nuts that hold the lamp in place. Be careful not to drop the nut (hehe), it'll be impossible to find. Once the nuts are off, pull the rear cluster out. It's clipped on with a plastic piece so you'll need a bit of force. Don't worry, nothing will break. Once it's out, apply pressure to the top of this connector using your screwdriver:
And pull the plug out. Make sure when you pulled the cluster out, the white plastic clip stays on the car. If it's stuck on the cluster like so:
Pry it off with the screwdriver:
Now, the fun part. You have to wreck your stock connector on the car side. If someone knows how to do this without wrecking it, let me know! It's important that the metal clips at the end of each wire is not broken, thus, it's better to wreck the plastic clip which is replacable if you want to go back to stock. Stick the allen key into the slot with no wire and push up on it:
This lifts the top clip cover up slightly, use your screwdriver to pry the entire cover up like so:
Then pull the whole top off:
Next, use the screwdriver and carefully lift up each of the plastic tabs that hold in the metal clip at the end of the wire:
Pull the wire out carefully to avoid damage:
Once all the wires are pulled out, your clip should look mangled like this hehe:
Grab the new connector:
Look at it from the end. There are 4 holes on the top row and 2 on the bottom on each corner. I'll number them for reference.
1 2 3 4
5 x x 6
The clip looks like this:
The passenger side wires are as follows:
2 - Grey
3 - Red
4 - White w/Black Stripe
5 - Orange
6 - Yellow
The driver side wires are as follows:
2 - Green
3 - Brown
5 - Purple
6 - Light Green
Remember the white plug? Make sure it's still on the car. If you had to remove it from the cluster, slap it back on the car like so:
Plug the new connector into the car. Test the 4 lights. Reverse, lights on (dim brakes), brakes on, and turn signal. Once it's tested, push the cluster in, bolt the 2 nuts back on each side carefully... make sure you don't drop the nuts! Close the covers, and you're done!
Enjoy!
rage2
My Yaris Diary - All about my new Yaris!
My Blog - F1 News, Hotties, and Random Crap
My Site - Beyond Car Forums
rage2 is offline   Reply With Quote
Need 07 Sedan Tail Light wiring info ASAP atebit General Yaris / Vitz Discussion 3 09-07-2013 07:48 PM
DIY: LED side mirror installation eTiMaGo DIY / Maintenance / Service 85 06-24-2011 12:48 PM
GROUP BUY - JDM (RS) Vitz LED Tail Lamp ... riceboy Items for Sale by private party 453 07-14-2007 09:30 AM
T-Sport Tail light Sales Links Yaris TTE JWRC Cosmetic Modifications (Exterior/Interior) 8 01-24-2007 12:07 AM
Smoke your own tail lights ChinoCharles Cosmetic Modifications (Exterior/Interior) 9 01-16-2007 12:00 AM
