Old 07-14-2007, 07:00 AM   #1
Poser 101: Fake Carbon Fiber application
Sooo I was at the shop pickup up the aftermarket stuff for the GB, and I see a box with a roll of very good looking carbon fiber sticker... not the usual printed vinyl, but this one has an actual sheen and reflection to it like the real stuff.
So, just for the sheer heck of it, I get it, for experimentation's sake.
First order of the day, something easy, the emergency blinkers button and the blank plate on the other side:
Looks pretty good compared to REAL carbon fiber:
The only thing is, it's not glossy, but maybe a bit of clearcoat could resolve that...
I tried my luck with the whole trim piece, but the result was pretty disastrous:
The sticker is actualy a very thin, textured metallic sheet, so it does not stretch at all. Still, it's nice to get a preview of what it could look like with proper aftermarket CF trim pieces!
So here's the final look:
I had a lot left over, and the only other relatively flat piece of interior I could find was the blank switch holder at the base of the handbrake:
Not that great, I admit, but hey, it's all in good fun
Old 07-14-2007, 08:27 AM   #2
Meteorite Man
Passin' The Gas...Station
Meteorite Man's Avatar
Drives: Same As You But Different
Send a message via Yahoo to Meteorite Man
You may be able to form it with some heat....start from one end and knead it into place. It my get rid of those wrinkles.
Chuck
MY Gas Station Attendant Misses Me...
Chuck
Meteorite Man is offline   Reply With Quote
Old 07-14-2007, 08:37 AM   #3
brickhardmeat
Lonesome Cowboy
brickhardmeat's Avatar
Drives: 2007 WHITE HATCHBACK
stickery
I hope you don't have a mess to clean up when you peel it off but if you end up getting CF replacment pieces I guess you won't have to worry about that.
Really this does look better than those crappy 3M dash kits.
SPONSORED BY
Old 07-14-2007, 08:50 AM   #4
Chuck
Hmm thanks I could try that later, but it'll still be very hard as the material is metallic.
Originally Posted by brickhardmeat View Post
stickery
Nah it's a low cling adhesive, you can pull it right off with no residue
Old 07-14-2007, 08:51 AM   #5
jimcat
Green is good
jimcat's Avatar
Drives: Vitz RS
Send a message via MSN to jimcat
ha ha... i like that little green car
jimcat is offline   Reply With Quote
Old 07-14-2007, 08:53 AM   #6
brickhardmeat
Lonesome Cowboy
hey, that is fun stuff since it doesn't wreck your interior when you peel it up
SPONSORED BY
Old 07-14-2007, 09:24 AM   #7
njyaris
YARIS NEWBIE
njyaris's Avatar
Drives: YARIS 07 LIFTBACK
Send a message via AIM to njyaris Send a message via Yahoo to njyaris
not bad at all ..
Hudson County, New Jersey
njyaris is offline   Reply With Quote
Old 07-14-2007, 09:48 AM   #8
Black Yaris
der Zeck
Black Yaris's Avatar
CF racing stripe?
Old 07-14-2007, 09:51 AM   #9
Chris07LB
Chris07LB's Avatar
Drives: Yaris Liftback
Thats the best looking fake CF I've even seen.
Thomas, a little heat goes a long way when trying to wrap compound curves and such... reguarding your trim attempt.
Old 07-14-2007, 09:56 AM   #10
Black Yaris
der Zeck
I was thinking the same thing, even metal bends with heat
Old 07-14-2007, 10:17 AM   #11
CF racing stripe?
hehehe... it's just a sticker sheet, putting it through a normal vinyl cutter should be possible, CF yarisworld sticker maybe?
Mmmkay, I'll have to find a hairdryer and see if anything can be improved... But after seeing it, I'm not sure if I want that whole trim piece in CF now
Old 07-14-2007, 10:20 AM   #12
yrsdrgn
yrsdrgn's Avatar
Drives: 2007 Yaris
it looks pretty cool. i was planning on doing that with the door handle pieces.
Old 07-14-2007, 12:04 PM   #13
slvryaris
slvryaris's Avatar
Drives: 2007 Yaris Sedan S
Looks good. The heat would help it conform to the surfaces better as evryone has added.
Old 07-14-2007, 12:43 PM   #14
Meteorite Man
When you cover something and plan on using the heat, definately make it bigger than needbe. I'm sure that stuff will shrink. Wrap the piece of CF around the backside/edges so when you reinstall it the piece you covered will pinch the CF and not allow it to move or come undone.
Chuck
Chuck
Old 07-16-2007, 02:09 AM   #15
looks good, i would do that to my interior too, but i really don't have the patience for it.
Old 07-16-2007, 02:17 AM   #16
smokinyaris
smokinyaris's Avatar
Drives: bad boy
where can we get some sheets of cf stickers......
smokinyaris is offline   Reply With Quote
Old 07-16-2007, 02:55 AM   #17
Jerkratt
Jerkratt's Avatar
im friends with the lady at the local vinal shop im also friends with someone who works there.. i can get some made out....
"It hurts more when its wet"
Old 07-16-2007, 10:02 AM   #18
redduck
http://www.decalfx.com/carbon_2_sheets.html
carbon fiber sheets the shite has how to videos as well
redduck is offline   Reply With Quote
Carbon Fiber parts chino_potato Cosmetic Modifications (Exterior/Interior) 42 08-18-2007 12:49 PM
carbon fiber B pillar accent yrsdrgn Cosmetic Modifications (Exterior/Interior) 35 08-06-2007 05:13 AM
Carbon Fiber Engine Cover R0ME0 Cosmetic Modifications (Exterior/Interior) 15 06-06-2007 08:10 AM
Carbon offsetting with TerraPass BailOut General Yaris / Vitz Discussion 14 05-28-2007 12:29 AM
VIS Carbon Fiber Hood redglare45 Cosmetic Modifications (Exterior/Interior) 12 03-08-2007 11:23 PM
