Old 11-12-2025, 01:44 PM   #1
sinead
Drives: Toyota Yaris 2009
2009 Yaris cranks but won't start
Hi everyone, I'm hoping someone could help me figure out what has happened to my car.
I have a Yaris, 2009 with 265,000Km. I was driving to work, stopped at the traffic and the car stalled. The car was cranking but would not start, all warning lights were on. The lights and radio still work.
Brought it to a mechanic, they thought it was a crankshaft sensor issue. New sensor put in and still won't start. It was swapped out for another sensor and still wouldn't start. The following were checked and were fine; battery, alternator, ignition fuse, spark plugs, immobilizer, starter relay. Car is getting plenty of fuel and still returning an error code for the crankshaft sensors.
Before all this happened the car was fine, there was a P0420 code before but mechanics said that wouldn't cause this issue. I used cataclean too and the car was driving perfect.
Has anyone been through something similar? What was the solution and what do you recommend?
sinead is offline   Reply With Quote
cranking no start, crankshaft sensor, won't start
Yaris 2009 won't start drusoider DIY / Maintenance / Service 1 05-22-2018 04:13 PM
Yaris II D4D 2009 Won't start davidof General Yaris / Vitz Discussion 0 07-03-2017 08:17 AM
Toyota Yaris 2007 car wont crank no start aamrkhan DIY / Maintenance / Service 0 01-19-2015 10:31 AM
