Old 07-29-2007, 02:23 AM   #1
Spades
The Hated One
Spades's Avatar
Drives: 07 White Manual Sedan
Few new pictures of my sedan
there are a few more pictures in my garage of the exhaust and shifter, I wont bother posting those though.
So, flame away!
Old 07-29-2007, 02:44 AM   #2
looking good, looking good... black and white schemes always look good.
what can you tell us about that air filter enclosure?
Old 07-29-2007, 07:14 AM   #3
cleong
Parallel Parking Pro
cleong's Avatar
Drives: Yaris 1.5 Manual
Might be an attempt to shield the air intake from the heat in the engine bay? Probably he's running a pod filter as well.
Leong's NCP91 Toyota Yaris E
TRD Blue brake pads
DC Sports header
Old 07-29-2007, 09:29 AM   #4
Yaris Palme
MAZDASPEED3
Yaris Palme's Avatar
Drives: MazdaSpeed3
Send a message via ICQ to Yaris Palme
hey man nice car. the wheels look like the same as mine :D
DOTZ DAYTONA DARK.
Yaris Palme is offline   Reply With Quote
Old 07-29-2007, 04:13 PM   #5
Spades
The Hated One
Spades's Avatar
on the air box, the stock opening on the side of the airbox facing the engine was fiberglassed shut, and a 6"x3" opening was cut in the front of the factory air box, and a 3" round hole in the side of the box facing the fender. aluminum sheeting was used to channel the cold air flow to the openings.
A drop in K&N filter replaced the factory paper element.
after that I fabbed a alimunum box to help shield the factory airbox from engine heat and also give it a finished smooth look.
I have had bad luck with re-positioning MAF sensors on cars like this, generally with this MAF set up you will get CEL's and the fuel/air mixture will be off. so I am using the stock location for the MAF...but I am altering the housing to get more air(colder air too) for hopefully a bit more HP.
Sounds like it has a intake, looks good, thats enough for me.
The mounting plates for the strut tower brace I will be fabricating will be diamond plate also to go with the theme, and a couple other covers will be made from the polished aluminum diamond plate as the airbox.
the interior will get some polished aluminum added to it, and the rest of the interior and possibly the plastic engive valve cover shield or whatever you want to call it will be done in carbon fiber.
I am trying to keep the car black,white,and polished aluminum...other colors just seem too much when dealing with a white car and I like a smooth clean look.
Old 07-30-2007, 10:03 AM   #6
CameraCrew
CameraCrew's Avatar
Drives: Absolutely Red Yaris LB
Do you have side air bags? I ask because our Yaris has side airbags and we can't use seat covers.
Avoid Stoopid
CameraCrew is offline   Reply With Quote
Old 07-30-2007, 10:06 AM   #7
eco
eco's Avatar
Drives: 2007 Black Yaris sedan
Looks good,keep it up.
eco is offline   Reply With Quote
Old 07-30-2007, 05:30 PM   #8
Spades
The Hated One
Spades's Avatar
nope, stripped down model...didnt even have a radio...this was the basic of the basic...i will be getting some of the S sedan parts to clone it to one, but i didnt want all the power features a S had anyway.
Why people choose a 5dr Liftback instead of a Sedan?? SimmZ General Yaris / Vitz Discussion 53 05-29-2007 10:28 PM
