Old 12-26-2025, 07:36 PM   #1
zavan
Drives: Yaris Hybrid 2017
Correct front suspension for 185/60R15
Hi all,
Apologies if this has been discussed before, but I'm having trouble finding the right suspension for my 2017 Yaris Hybrid.
The local Toyota authorised service suggested two codes to me that are equivalent to the following front KYB: 339756/339757.
The problem is that my Yaris use 185/60R15 tyres, and KYB states that these are not to be used with this dimension.
Instead, KYB suggests 333746/333745 for this dimension, which are not available anywhere.
Did any of you have this issue before, and how have you finally solved it?
Thanks.
zavan is offline   Reply With Quote
185/60r15, front, kyb, suspension
Front Suspension Front Ball Joints Sweating! IftyH General Yaris / Vitz Discussion 5 12-27-2022 12:56 AM
ABS Code Keeps Returning After Sensor Replacement Code 31 Front Right Chwbcca DIY / Maintenance / Service 5 09-15-2021 08:16 AM
Would these front suspension parts be any good? Pinchlite Wheels, Tires and Suspension Forum sponsored by The Tire Rack 13 02-09-2017 10:07 PM
2012 Nissan Versa Kal-El Off-topic / Other Cars / Everything else Discussions 22 06-15-2012 04:48 PM
