Old 03-14-2026, 12:03 PM   #1
Carlo
Drives: Yaris automatic diesel 2009
Yaris gearbox fluid replacement
Hi I'm seeking advice here if I may? It's a 2009 Yaris automatic diesel that needs the gearbox fluid replaced as the sump rubbed has corroded and when checked the fluid was minimal. So I'm hoping for some advice on where exactly on the gearbox can I find where the fluid goes into it? From research it's located at the side near the top but when I've looked there's a break plate attached to the gearbox which I've not seen on the diy repair videos.
Thanks for any advice.
Carlo is offline   Reply With Quote
3rd gen 2zr swap with 6 speed stidnam Performance Modifications 97 06-29-2021 04:59 AM
Manual trans fluid change 2010 Yaris 3dr LB DANIELTNIEVES DIY / Maintenance / Service 2 08-21-2015 09:52 PM
