Old 03-14-2026, 07:05 PM   #1
Gmund1949
Drives: 2012 Yaris hatchback
wheel adapter
Hello fellow Yaris owners! Quick and easy question. I just received 4 brand new wheels and tires from a Honda Civic (1993 Del Sol) and want to put them on my 2012 Toyota Yaris. Anybody know where I can get adapters? Same size tires and wheels . . . the studs just don't line up on the wheels. Again, 1993 Honda wheels . . . trying to put them on my 2012 Yaris. Thanks, pfm2@lehigh.edu My username here is: Gmund1949
Gmund1949 is offline   Reply With Quote
Old 03-15-2026, 11:22 AM   #2
From Google Ai
"The Honda Civic del Sol (1993–1997) uses a 4x100mm bolt pattern (4x3.94 inches). This 4-lug configuration is standard across all del Sol trims, including the S, Si, and VTEC models. It uses M12x1.5 lug nuts, and typically requires high positive offset wheels (around +35mm to +45mm)."
Since the Yaris is 4x100, I can't see why your wheels are not lining up with the studs.
ABS, BRAKE, Harness Troubleshooting Diagnostic Guide XP90 2nd gen IndestructibleYaris DIY / Maintenance / Service 0 09-05-2024 05:19 PM
Wheel bearing / Outer TRE / Control Arm replacement howto shepd DIY / Maintenance / Service 3 09-14-2015 04:20 PM
Steering wheel hub adapter spdfrk Cosmetic Modifications (Exterior/Interior) 7 02-18-2011 04:44 PM
Steering wheel adapter for TS sadha Yaris TS Talk 4 07-14-2010 09:32 AM
