Old 03-24-2026, 05:19 PM   #1
urobsolete@gmail.com
Drives: 2010 Yaris 4 dr Hatchback
starter seems to disengage late
I have searched the forum. Some issues sound exactly like mine. However, the solution suggested did not remedy the problem.
When the engine is cold, as in overnight or 4 to 5 hours, the engine starts, but makes a loud grinding/screeching noise after it starts and the bendix should have retracted. Replaced starter with new Toyota starter. No change until the engine has warmed. I just reinstalled the original starter after 3 months, while I investigate, gather info and recommended troubleshooting tips.
Thanks,
Ray
urobsolete@gmail.com is offline   Reply With Quote
Old 03-24-2026, 08:03 PM   #2
Tamago
Tamago's Avatar
Drives: UZJ100
how cold is cold? it's possible you're partially freezing the starter maybe?
bendix, grinding noise, noise, starter
starter whirring before catching the flywheel YOUNG SCOOTER DIY / Maintenance / Service 2 11-29-2021 07:11 PM
2011 1.3 Yaris wont start-silence from starter motor Biggles DIY / Maintenance / Service 2 02-10-2021 12:47 PM
standard vs manual starter? Pinchlite DIY / Maintenance / Service 9 04-08-2020 10:50 AM
Starter Problems - Heads Up tmontague DIY / Maintenance / Service 6 03-01-2019 10:04 AM
Remote starter recommendation and questions GrayYaris DIY / Maintenance / Service 3 05-30-2014 01:06 PM
