Old 08-01-2007, 01:51 AM   #1
nurburgring
ringmeister
nurburgring's Avatar
Drives: YARIS 1.5
How to remove fog lamp covers ?
How do you guy remove the foggy covers ? Wanna open them up to let more air in.
nurburgring is offline   Reply With Quote
Old 08-01-2007, 04:09 AM   #2
slvryaris
slvryaris's Avatar
Drives: 2007 Yaris Sedan S
Water may get into them and cause the bulbs to blow premature due to condensation.
Old 08-01-2007, 04:39 AM   #3
nurburgring
ringmeister
Drives: YARIS 1.5
Mine are just covers, I dont have fogs.
Old 08-01-2007, 05:07 AM   #4
AFAIK they clip from the back, it'd be easier to remove the bumper to reach the clips...
Old 08-01-2007, 07:41 AM   #5
spinejaruk
spinejaruk's Avatar
Drives: Venetian Silver Yaris
alternatively, on each side you can remove three screws and a plastic plug (where the centre screw goes in) underneath the bumper - check out the service manual fog lamps under "lighting".
Pull out and flex the plastic shielding out to one side and stick your hand in - push the clips on the fog cover outwards and push forward - it may be easier if you have a buddy to assist and jacking up the car/or put on ramps depending how fat you are....
spinejaruk is offline   Reply With Quote
Old 08-01-2007, 10:58 AM   #6
ROCKLAND TOYOTA
TRIM HUNTER
ROCKLAND TOYOTA's Avatar
instead of taking them out completely i thought about using the dremel to cut some slits to give it some air.....
Old 08-01-2007, 12:38 PM   #7
CKMotorsport
CKMotorsport's Avatar
why don't u install billion air funnel and air duct instead. it's looks better.
CKMotorsport is offline   Reply With Quote
Old 08-01-2007, 12:44 PM   #8
Astroman
Modded Moderator
Astroman's Avatar
That is what I'm going to do, just can't find the dremel right now..
Old 08-01-2007, 03:21 PM   #9
OxyG3nE
Drives: Toyota Yaris 2007
Send a message via AIM to OxyG3nE Send a message via MSN to OxyG3nE
iif u have the CAI it probably help to open it.. its right under where the filter goes .. was thinking about doing it too.. when its not raining..
OxyG3nE is offline   Reply With Quote
Fog lights and shift knobs flip_yaris Cosmetic Modifications (Exterior/Interior) 3 10-20-2008 05:36 AM
Fog Light Covers for Inspection razzorjet2 DIY / Maintenance / Service 2 05-01-2007 05:41 PM
question on Fog light clfile Cosmetic Modifications (Exterior/Interior) 6 11-09-2006 07:11 PM
Fog lights and shift knobs flip_yaris Cosmetic Modifications (Exterior/Interior) 4 09-26-2006 10:48 AM
Fog lights for S sedans (US version) paeko73 General Yaris / Vitz Discussion 11 07-02-2006 11:38 PM
