Old 08-07-2007, 07:05 AM   #1
bigbutch
Drives: Dynamic Blue Metallic Mica YRX
18' mag wheels
Does anybody know if 18's will rub anywhere or would i be safer with 17's
not planning on lowering
and what offset would be the best
i see the trd mag wheels are 18x7.5 +45 should i stick to the same offset or would +42 be better
thankyou anyone that can help is much appreciated
(Just took delivery of my yaris YRX, dynamic blue metallic, 5 speed has done a 110kms on first day lol)
bigbutch is offline   Reply With Quote
Old 08-07-2007, 08:30 AM   #2
RShatchback
Drives: 07 yaris liftback
Plenty of people are lowered with 18s and have no problems. I think if you use 17s and a low pro tire and the car isnt lowered the wheel well gap is going to look ridiculous. It would probably look a little better with 18s, either way, without going low the car is going to look like a mini monster truck..
Car forums are kinda like the public library - somepeople are just checking stuff out, and plenty of other people are just telling stories...
RShatchback is offline   Reply With Quote
Old 08-07-2007, 10:36 AM   #3
Black Yaris
der Zeck
Black Yaris's Avatar
Please click on my signature for recommended tire sizing
+42-45 will be fine.... on a 3 mm differeance
Old 08-07-2007, 10:52 AM   #4
kimona
kimona's Avatar
Drives: 2014 White VITZ
You can easily run 18's or 19's without any rubbing problems. However, without lowering, your Yaris will look a little silly. The problem is that the wheel gap will be greater than the sidewall, and the gap will be further accentuated running at the outerlimits with a 7.5, ET45.
Old 08-10-2007, 10:02 AM   #5
bigbutch
would a +42 be alright front and back or would i have to get staggered offsets
Old 08-10-2007, 10:14 AM   #6
Black Yaris
der Zeck
you do not have to run staggard offsets.... staggard is just a prefferance for some
Old 08-10-2007, 10:36 AM   #7
kimona
kimona's Avatar
Hey mate,
ET42 would be okay all 'round. A staggered offset application may look a bit better, but it certainly isn't necessary.
I presume you'll be running 215/35's on 18's. That being the case, you need to run high offset rims otherwise the tire sidewalls will poke out up front, which will look especially go-cart like since you won't be lowering the car.
For your application, I would recommend rims with ET45-48.
Feedback on these wheels BulletProofAuto Wheels, Tires and Suspension Forum sponsored by The Tire Rack 21 06-04-2007 08:09 PM
Buddy Club Wheels BulletProofAuto Sponsors Classifieds Area 8 10-19-2006 06:55 PM
Do bigger wheels and tires improve performance Driver Wheels, Tires and Suspension Forum sponsored by The Tire Rack 14 10-14-2006 06:01 PM
