Old 08-14-2007, 10:24 AM   #1
YoyotaTaris
YoyotaTaris's Avatar
Drives: 2005 Yaris VVT-i T2
Door Panel/Speakers- Help Needed (pic included)
Hey guys
I am trying to install new speakers into my Yaris. It is a 2005 T2, which has a manual window control.
I tried to get the door panels off, but the Window handle doesnt pop out. It prevents the door panel from coming off.
Does anyone know how to get the window handle off? I have attached a picture of the door in question.
Thank you for reading.
YoyotaTaris is offline   Reply With Quote
Old 08-14-2007, 03:15 PM   #2
fu_im_from_texas
fu_im_from_texas's Avatar
Drives: Liftback
Send a message via AIM to fu_im_from_texas
... its easy once youve done it a few times... use a rag and "saw" it back and forth between the crank handle, and the plastic door spacer... check out the pics in this thread...
http://www.yarisworld.com/forums/sho...t=window+crank
fu_im_from_texas is offline   Reply With Quote
Old 08-14-2007, 03:18 PM   #3
dimmunize
Drives: 2007 yaris S
hmm.. I own a 07 sedan-S model.. so i'm not sure.. but from the looks of it, it looks as though the entire panel where the speaker is located can come off.. I would try that first. there should be some plastic clips holding it on and if your not afraid to try it, try some plastic putty knives on the panel and see if you can loosen it up enough to pry it open, then removing your speaker should be easy and you won't have to remove the window handle.
dimmunize is offline   Reply With Quote
Old 08-14-2007, 03:47 PM   #4
YoyotaTaris
Ok I think I understand. There is a Clip on the door handle, on the other side of the door panel. Just to make clear, there are no screws involved, right?
Old 08-14-2007, 05:40 PM   #5
SiliconRane
Dr. Trunk Monkey
Drives: 2007 Red Yaris
correct, no screws, my suggestion is to take it to a car shop and ask them to take the clips off the window handles . . . they should do it for free . . . they have a little tool that does it! Re-installation is a cinch just snap them back on when you are done!
SiliconRane is offline   Reply With Quote
Old 08-14-2007, 08:09 PM   #6
johnnyfive
johnnyfive's Avatar
just like flosing the handle with a rag until you get the clip to pop off, just make sure get the clip back, 95% of the time it will be in the rag, but it can come poping out of there pretty quick ;)
or you can spend a couple pounds, and buy the removal tool :)
Old 08-14-2007, 09:47 PM   #7
hystria
hystria's Avatar
Drives: 2007 Orange Yaris Hb 3Drs
or try to "push" into the spring with a flat screw driver (push on the door panel to obtain some clearance)
hystria is offline   Reply With Quote
Old 08-15-2007, 02:09 PM   #8
YoyotaTaris
Ok, Got it. It came off, went flying half a mile down the road, but the important thing is that I found it. And it will probably happen again when I have bought the Speaker Brackets and need to install them.
I totally forgot about the Speaker brackets though. Any ideas where I can buy them in the UK. Couldnt find anything on Ebay, dont know if Halfords sell them.
I know I can make them out of MDF, but where do I buy some MDF?
I am a newbie...:(
Old 08-15-2007, 02:15 PM   #9
ChinoCharles
Drives: LB
Its OK to be a newbie... despite what BlackYaris says.
http://www.yarisworld.com/forums/sho...peaker+bracket
That may help a bit... not sure though.
Old 08-17-2007, 07:00 PM   #10
earljail
earljail's Avatar
Drives: 07 Yaris Hatch 5speed
You can also cut the old speaker out and reuse the speaker holder.
Pic request: Canadian & EU roof rack SmellyTofu Photo-Video-Media Gallery 11 04-03-2010 03:49 AM
Pic Request: Scangauge mounted in pocket under single din CD player? nebulight In Car Entertainment + Electronics (audio / video / alarm) 1 04-29-2007 06:56 PM
Super Advan pic for the_saint esquiva Wheels, Tires and Suspension Forum sponsored by The Tire Rack 2 11-11-2006 01:24 PM
