Old 08-16-2007, 04:52 PM   #1
jm1681
Janghwa, Hongryeon
jm1681's Avatar
Drives: 20th AE VW GTI
Bridgestone RE750, 205/55-15
Anyone running this tire?
I checked the "math" section of the tire guide, but it seemed like another language to me :(
Basically, if I'm running the OEM wheels, will this tire (A) fit, and (B) have the same rolling diameter?
22B | 藤原とうふ店 | Fatal Frame | 呪怨 | 장화,홍련 | Strong Bad
How to survive a Zombie attack
"The inerasable scars, left by the palms of my hands"
365tuners
jm1681 is offline   Reply With Quote
Old 08-16-2007, 06:28 PM   #2
brickhardmeat
Lonesome Cowboy
brickhardmeat's Avatar
Drives: 2007 WHITE HATCHBACK
http://www.miata.net/garage/tirecalc.html
SPONSORED BY
Old 08-16-2007, 10:42 PM   #3
kimona
kimona's Avatar
Drives: 2014 White VITZ
Yes, 205/55/15 will fit your stock steel rims with no problem. And, yes it is the recommended replacement upgrade size for 185/60/15 with basically the same diameter. Install 205/55/15's with confidence.
*Oh, BTW, post some feedback and pics when you upgrade tires so other members can benefit from your experience.
Old 08-17-2007, 08:06 AM   #4
jm1681
Janghwa, Hongryeon
jm1681's Avatar
Originally Posted by brickhardmeat View Post
Where do you think I got the size ;) That site is bookmarked on every computer I come in contact with :D
Only reason I asked was because the tire guide mentions something about rim width also playing a part in selecting the aspect ratio.
365tuners
Old 08-17-2007, 08:13 AM   #5
kimona
kimona's Avatar
Recommended rim width for the OEM 185/60 (23.7") is 4.5-7.0"; for the 205/55 (23.9"), it's 5.5-7.5", so you'll be fine.
Old 08-17-2007, 09:46 AM   #6
jm1681
Janghwa, Hongryeon
jm1681's Avatar
Cool beans :)
I figured it would be OK, just making sure. I've been modding cars for years and I've had two "awakenings" in two days on this site.
Crazy stuff I tell you :)
365tuners
Old 08-19-2007, 04:51 AM   #7
Masteraal
Masteraal's Avatar
Drives: Black Yaris YRS 3dr Manual
hang on the stock steelies can handle up to 205's?
185/60/R15 is stock i think
Masteraal is offline   Reply With Quote
Old 08-19-2007, 09:23 AM   #8
kimona
kimona's Avatar
Yes, see post #5 above for recommended wheel widths.
Old 08-21-2007, 11:44 AM   #9
Black Yaris
der Zeck
Black Yaris's Avatar
that is a perfect size.... that is what I am running for my winter tires on my stockies.....
Old 08-21-2007, 11:45 AM   #10
Black Yaris
der Zeck
or just click on my signature for recommended wheel/tire widths from 14-20 inch rims
Old 08-22-2007, 09:09 PM   #11
hey, just try not to use 205's on the stock 5.5" width wheels.
i run 195/55R15 on my Yaris1 Ts wheels, and they are already pretty buldged.
Old 08-22-2007, 09:14 PM   #12
kimona
kimona's Avatar
Well, 195/55's will work fine enough, but 205/55's are within spec and they do fit the 5.5" wheel within recommendation... no problem. Plus, 205's will fill the huge gap better and provide more of a footprint.
Old 08-23-2007, 01:34 AM   #13
Black Yaris
der Zeck
205's are fine on 5.5 wheels... like kimona said.... wider footprint
Does anyone here know why Bridgestone tires are so expensive? grampi Wheels, Tires and Suspension Forum sponsored by The Tire Rack 10 06-03-2007 11:10 PM
