Old 06-30-2006, 02:34 PM   #1
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
remove dealer emblem...help!
How does one remove the dealership high speed plastic emblem from the vehicle?
Old 06-30-2006, 05:41 PM   #2
punch
punch's Avatar
uh?? if it an emblem the dealer stuck on advertising there shop, should just peel off (and use a plastic spoon, or popsicle stick), and finally remove residue glue, with a product called goof-off, goo begone etc...
or take the car back to them say you didn't pay for advertising and want it removed at there expense.
Old 06-30-2006, 06:18 PM   #3
Chris07LB
Chris07LB's Avatar
Drives: Yaris Liftback
Best way to remove dealer emblems, any emblems for that matter, is to get some fishing string, and start "cutting" thru the adhesive backing behind the emblem.
Follow that up with a little "GooGone" or "WD40" to remove any left over residue.
Old 06-30-2006, 07:09 PM   #4
pennystocks
pennystocks's Avatar
Drives: 07 Civic Si Coupe(Black Pearl)
Mine just came right off thank god. Now the car maxx on my TA, that was a b1tch. Bought some un-stick in a can at walmart for like $5 and let it sit for a while.
pennystocks is offline   Reply With Quote
Old 07-01-2006, 12:07 AM   #5
yariman
Speed Wrenchin'
yariman's Avatar
Drives: 2006 Yaris 3 door, Bayou Blue
Let it sit in the sun and warm up. If no sun, heat up with hair dryer or heat gun ( carefully ) then peel off slowly, clean residue with brake clean. Careful if you use goof-off for the residue.
Quench my thirst with gasoline
yariman is offline   Reply With Quote
Old 07-01-2006, 05:54 PM   #6
fnkngrv
fnkngrv's Avatar
Thanks for all the advice...I just didn't want to try to peel and then regret it.
Old 07-01-2006, 06:53 PM   #7
fearturtle44
Drives: S Flint Mica
Good luck. I got smart with my last 4 cars and had them not to put on to begin with. I told them I would let them is they paid me $20 for the free advertising. For some reason, they never took me up on it. HA
Kevin
fearturtle44 is offline   Reply With Quote
Old 07-01-2006, 07:01 PM   #8
slvryaris
slvryaris's Avatar
Drives: 2007 Yaris Sedan S
If it is on a brand new car just wait till the sun heats it up and they should peel right off. if it is like thew generic letters just go to the car wash and blow them off. The newer the car and the paint the easier they are to peel off. Well U could always use a heat gun or a blow drier...Just dont keep it on there long cause U will hurt the clear coat.
Old 07-02-2006, 12:51 AM   #9
TRD_Yaris
Yarii Hunter
TRD_Yaris's Avatar
Drives: 2007 Yaris Liftback and S13's
after heating the area with a hair dryer / heatgun you can use DENTAL FLOSS to remove the sticker/emblem. Be careful of trying to "pick off" the emblem because you will MOST likely damage the paint. I can't remember if waxed/unwaxed was preferred, though..but it doesn't really matter.
after removing the sticker, wash the area thoroughly with soap/water. If the old glue doesn't come off, mix in more and more carsoap or trying using Dawn (degreasing elements in it are awesome, but it will strip your wax as well).
TRD_Yaris is offline   Reply With Quote
dealer is telling me no power option avail in my area twixt New YARIS Purchase Forum 56 06-15-2007 12:10 PM
How do i remove plastic interior? David81 Cosmetic Modifications (Exterior/Interior) 1 06-09-2006 09:07 AM
Dealer MOD's silverRS General Yaris / Vitz Discussion 8 05-08-2006 04:18 PM
