#1 |
Toyota Newb!!
Drives: Yaris S Sedan w/ Aero Package! Join Date: Jun 2006
ATTN: Don't buy REAR Stoptech SS Lines!!
Just wanted to give a heads up to everyone thats interested in the Stoptech REAR Stainless Steel Brake Lines.
I just called Stoptech and confirmed that they made a big boo boo on their part for the catalog. Our cars being a rear drum setup we can't use the lines that they offer....the front lines should be ok...i'm getting those installed next week. So far no news on developing rear drum lines as of yet...i am told. |
thanks for the heads up
#3 |
der Zeck
Drives: '05 Audi A4 1.8t quattro Join Date: Sep 2006
shouldn't we only have one rear brake hose? we have a solid rear dead axle, the line should go right up to the cylinder from a "T" and a Hose off the "T" to another line going to the Master Cyl.... I did not pay attention last time I was up under there..... but that is usually how things go, correct me if I am wrong
#4 |
Toyota Newb!!
No idea dude...i haven't taken a look yet...
I think i just might have to return the whole stoptech package and get the Goodridge set...as the kit they have includes the rear drum brake lines as well... |
#5 |
Spool'd
Drives: 07 yaris, 16 gen coupe rspec Join Date: Aug 2007
How would ABS for the rear wheels work if both rear brakes were powered by one brake line? From everything I've ever been taught working in the Toyota garage, ABS needs 4 independent brake lines that all run to the central unit thing under the hood, usually near the brake booster...forget the name of it now. Looks like a block of aluminum with brake lines coming out all over it.
#6 |
Hi!
my tacoma had drum brakes, solid rear axle, and one brake line... but no abs as well.
#7 |
I had a 93 S10 where, I shit you not, the ABS consisted of a speed sensor and valve (rear wheels only) that would quite literally shut off your rear brakes when they locked up. You'd be amazed at what manufacturers can get away with when it comes to naming parts in a sales brochure. Take the Yaris for example: I see a solid beam rear axle with coil springs, and Toyota's marketing department sees a "tortion beam rear suspension". Yeah, ok. When I hear that I think of tortion bar suspensions that are typically found in older Chrysler cars and modern 4x4 trucks, not a plain beam and springs suspension. It all comes down to properly applied naming or not, they'll call it what it needs to be called to sell vehicles.
#8 | |
![]() ![]() Drives: '08 Polar White 3dr Join Date: Jun 2007
Buyer: You mean the nifty cup holder? Saleman: errr, yeah the nifty cup holder. |
#9 | |
![]() ![]() ![]() Drives: Silver 2007 3Dr - Gryph Join Date: Jul 2007
The only difference between a 'twist axle' rear and a 'true' torsion-beam rear is if the rear axle is two parallel (at rest) rods cross-linked or one single rod. The two parallel rods gain a minor design-engineering-simplicity advantage at a moderate complexity disadvantage. The single-beam is, in effect, two half-length torsion bars linked at the mid-point by comparison, and more math and proper design can let it perform almost well as the two-rod setup AFAIK, though it doesn't add as much chassic-rigidity as the two-bar setup. This is (I believe) why a rear sway bar is so noticable on the Yaris.
#10 |
Drives: lil red 5-door Join Date: Sep 2006
Engineer jargon overload
![]() But I think I understand and agree with what you mean, take a look at the technical manuals for download in the DIY section, you can see that the hinges for the rear beam are angled, so there would be some torsional action when the suspension moves.
The price of freedom of religion, or of speech, or of the press, is that we must put up with a good deal of rubbish. - Robert Jackson ![]() Bye bye 1NZ... |
#11 |
Go read the Car Bibles.com Suspension Bible and it'll help explain things.
#12 |
Break'em off some.
Drives: 07 Yaris LB, 04 Cobra Join Date: Jan 2007
I thought there were 4 rubber lines for the rear. I dont remember for sure, as the last time I was looking back there was when I lowered it 6 months ago.
#13 | |
#14 |
Changed the car from being squirreley and 'squiggley' when in extended turning (sweepers or doing figure-eights around a pair of orange cones in a parking lot) to taking a quick 'set' under load and being very easy to control with throttle-adjustments and responsive to turning. Exactly what you'd expect from an unstiffened chassis suddenly getting properly stiffened, much more than just a rear sway bar would normally grant on a FWD car.
Without the sway bar the car felt like it was near-constantly under torque steer (the fuel cut-off deceleration causing it even under engine braking at highway speeds) but once I had the sway bar put on what I thought was torque steer turned out to just be how loose the rear chassis was magnifying things to very noticable levels. Hell, without the bar I felt unsafe doing my figure-eight practices to get used to how the car handled. I couldn't get myself to break 25mph. Once I put it on I had to stop when my passenger/friend started complaining about the alternating side-to-side G-forces I was pulling off doing 35-40mph figure-eights for ten seconds non-stop. Car feels much more chuckable, very much like my 89' Corolla FX used to feel, or my 86' Civic Hatchback felt.
#15 |
If you've installed rear springs you figure out their is a lot of flex in the torsion beam,and the rear spring perches will move independantly.
#16 |
Break'em off some.
#17 |
Sweetness. I feel a lot better about this then. Anyone know of a proven good front/rear sway setup and where to buy them?
#18 |
The Man In Black Lives
Drives: Black Sand Pearl L/B 'o7 Join Date: Jul 2007
TRD rear sway & Tenbe front strut . I got the rear one now am getting the front this week.....
black2yaris The Man In Black Lives! 2007 2 door hatchback in Black Sand Pearl, A/T,rear spoiler,front & rear JDM badges,TRD CAI,TRD rear sway bar,exhaust tip,sill protectors,heximats,under dash blue LED's,short rubber ant,rear bumper protector,Toyota thin 7 spoke alloy wheels,pwr pkg,ABS,side curtain airbags,rear defogger,fog lights,mud guards,TYC tail lights,shift knob,tint all windows,security sys,keyless entry,clear paint protection all exposed front surfaces,TRD fuel cap,rubber dash & g/b mats |
| When will the Yaris hit the showrooms at dealers? | Petrolhead | New YARIS Purchase Forum | 181 | 11-28-2011 07:03 AM |
| rear fog light and tuned rear lights | lefti696 | Cosmetic Modifications (Exterior/Interior) | 0 | 11-09-2006 03:06 PM |
