Old 09-16-2007, 09:07 AM   #1
c-one yaris
c-one
Send a message via AIM to c-one yaris
leaking!!!
i'm leaking black black oil right under the flywheel. it has no smell to it. is it possibly gear oil?? i got the car with 8 miles on it in mid june of 2007 and i now got 6600 miles. i already did my first oil change at 4949 miles.
c-one yaris is offline   Reply With Quote
Old 09-16-2007, 10:59 AM   #2
Desperauto
The Old Man
Desperauto's Avatar
Drives: 2008 yaris HB black sand pearl
Sounds like a rear seal going out for some reason, better get it checked out right away.
could mess us the pressure plate and clutch real fast.
Life is Grand
Desperauto is offline   Reply With Quote
Old 09-16-2007, 11:28 AM   #3
joey1320
joey1320's Avatar
Drives: Yaris LB
yeah sounds like your rear main seal is leaking. take it to the shop and get it fix.
Old 09-16-2007, 02:03 PM   #4
xpeteyjtx
Drives: 07 BB Yaris
Check your fluid levels and then drive to the dealer. You should still be covered under the warranty. Call the dealer, maybe they will tow if for you at Toyotas expense.
xpeteyjtx is offline   Reply With Quote
Old 09-16-2007, 07:14 PM   #5
nick1983
nick1983's Avatar
Drives: 2007 Toyota Yaris sedan
My 07 sedan had a similar problem. It turned out that it was a blown axle seal on the transmission. I took it to Toyota. They replaced it under warranty.
Hope this helps.
nick1983 is offline   Reply With Quote
Old 09-18-2007, 09:24 PM   #6
ToyotaTEch21
Drives: 2007 Yaris Sedan
gear oil should have a strong smell. we had one in the shop with a power steering leak but thats all I have seen so far.
ToyotaTEch21 is offline   Reply With Quote
Old 09-18-2007, 09:43 PM   #7
Black Yaris
der Zeck
Black Yaris's Avatar
Um don't we have electric power stearing?
Old 09-18-2007, 11:45 PM   #8
Lafiro
Drives: 06 Yaris Sedan
Electric power steering, on the Yaris!!?????
Yes we do.
Try this everyone, leave the car in the ON position, but DO NOT TURN THE CAR ON!
Put the car into nuetral, and roll it up maybe two feet while moving the steering wheel, and see what happens! To spoil the fun, even with the car OFF, you have complete and easy turning ability of the wheels. This is something the car comes with so incase it wont start(cause you ran out of gas or something) you can atleast move it and not worry about forcefully turning the wheel.
Old 09-19-2007, 07:50 PM   #9
ToyotaTEch21
Ya know I never questioned it myself, when the other tech told me it was a power steering leak I thought maybe the system uses fluid anyway. I never bothered to check. I also havent had to work on the system on a yaris yet. I'm gonna ask him tomarrow what the heck he replaced again and see what he says. I apologise for any confusion, I just took what he said as fact and didn't ask questions.
