Old 09-20-2007, 07:48 PM   #1
derrick452
maybe im an idiot, but....
If I were to get the TWM short shifter and bushings kit, will that effectively do the same thing that the NST short shift kit does?
Can I use both together to get a shorter, tighter shift pattern?
Is the shaft of the TWM short shifter actually shorter than the stock one?
Can anyone whos used both comment?
THANKS IN ADVANCE!!!
derrick452 is offline   Reply With Quote
Old 09-20-2007, 08:00 PM   #2
Black Yaris
der Zeck
Black Yaris's Avatar
the NST shifter makes shifting a lil harder, changing to synthetic trans fluid helps a bit. As for the TWM I am unsure, but it shortens the throw on the other side of the linkage and putting the bushings in will make for some super short and tough shifting.... worse case, you can always just pop the NST shifter off easily....
Old 09-20-2007, 10:48 PM   #3
both can be used together, but that's gonna give you some insanely short throws!!!
Old 09-21-2007, 03:01 PM   #4
derrick452
Kickin'. Thats what im looking for.
Old 09-21-2007, 03:12 PM   #5
eijikikimaru
Q(','Q)
eijikikimaru's Avatar
Drives: 3dr Meteroite
Looking at Reznuts TWM the shifter physical length is shorter then the stock length.
*FYI*
Short arms and stock seats I don't recommend the TWM shifter for you'll be leaning toward the shifter in order to shift gears.
Long arms stock seat you still lean but not too much.
Aftermarket seats w/ the TWM fits just right.
eijikikimaru is offline   Reply With Quote
Old 09-21-2007, 09:53 PM   #6
Indeed
Old 09-21-2007, 10:52 PM   #7
someone told me to be careful with short-throw shifters...something about the synchro's not being able to keep up or something? when i had my GTI, i had a short-throw that was set to 60% shorter w/o problems.
Some IDIOT got me hit the curb and need replace rim and tire. Ziv Wheels, Tires and Suspension Forum sponsored by The Tire Rack 16 06-09-2006 10:54 PM
