#1 |
Steals terrorist's lunch
Drives: 2007 Yaris Liftback Join Date: Mar 2007
Just in case anyone is curious about this, yes, the Yaris LB interior fits snowboards (or just a snowboard) without a problem.
The first image is a 155cm board laid flat and pulled up against the rear. The second image is a shot of the nose in that configuration, showing that you could easily fit a 157 this way, even a 159 if you move the passenger seat forward a notch. The last image is with the board on its edge, with the nose tucked just a bit alongside the passenger seat. Notice that there's lots of room left, meaning you could easily fit a 165 in this manner without an issue.
- Brian Share the Road I often carry 2 carpool passengers and mountain bikes or snowboards/skis over a 4,500 foot elevation difference. Click the graphic above to see my detailed mileage logs. Last edited by BailOut; 09-24-2007 at 09:30 PM. Reason: Added the word "snowboard" to make the search tool work. |
