Old 09-23-2007, 08:19 PM   #1
WolfWings
WolfWings's Avatar
Any recommendations for getting soundproofing installed?
Already know the product I'll be going with (RAAMmat) since I can get it affordably, but at this point I'm looking at the installation and wondering if anyone out there has some experience doing so? I'm good with mechanical stuff, but I'm actually worried about yanking the interior apart to do a proper floor-pan install myself, since I can't afford to have the car down for more than a weekend due to my work schedule.
Only thing I was able to find by hunting around was a price-quote in the $300-500 range from Best Buy for labor starting at the floor-pan getting layered up and working up to fully sealing the doors inside and out and doing everything but the roof of the vehicle.
So, my two-part question is: Is that a rip-off price ($300 for the floorpan is what I'm oogling mostly) for the amount of labor involved in such an install? And would Best Buy be likely to do a passable job in the first place? I have the stripped no-power-anything, no-extra-ABS, no-side-airbags model, so AFAIK it's as easy an install as can be done on the Yaris.
Old 09-23-2007, 10:09 PM   #2
Desperauto
The Old Man
Desperauto's Avatar
Drives: 2008 yaris HB black sand pearl
You have the right stuff.. And I worked with my son on a scion TC and RAAMatted it, it took 3 of us two 10 hour days to strip the interior and door panels and cover everything. Its quite labor intensive. we did the floor and the trunk and inside the doors. It was a real challange. 300 doesnt sound to bad for the floors. It does pay off though.
Life is Grand
Desperauto is offline   Reply With Quote
Old 09-23-2007, 11:26 PM   #3
tk-421
tk-421's Avatar
Drives: 5D-07-LB
Just curious: Why would you leave the roof out of the equation? IMO that's the noisiest part of the car (at least it feels like it on heavy rain and hail and stuff)
Old 09-23-2007, 11:43 PM   #4
earljail
earljail's Avatar
Drives: 07 Yaris Hatch 5speed
I've never soundproofed, but I've read that you need to get a kind of soundproofing meant for the roof, because if you get cheaper stuff, the glue won't hold it up, due to gravity and the high temperature.
However, if you're doing your whole car, you might as well finish the job.
Old 09-24-2007, 02:26 AM   #5
eijikikimaru
Q(','Q)
eijikikimaru's Avatar
Drives: 3dr Meteroite
I sound proofed the rear and the sides of my car(LB).
It's quite simple but it does take a lot of time. I spent 4x5hr days and worked on it by myself. I just removed the rear seats for that month and soundproofed each Saturday.
As for popping the parts off they're not difficult, just need to be careful to pull them off correctly. If pulled at an angle, you can chip,break,snap off those plastic pieces. The carpet is real simple, if i remember correctly if all plastic panels and seats are off the carpet just rolls off. Correct me if I'm wrong...it's been a while.
I felt better that I did the work myself but $300 doesn't sound so bad if they're going to do the whole car for you.
If you are going to do it yourself, invest in some rollers, they help a lot! I bought some cheap ones at home depot.
eijikikimaru is offline   Reply With Quote
Old 09-24-2007, 05:19 PM   #6
derrick452
I cant believe its that labor intensive....the stuff doesnt just stick to the floor?? Is it hard to cut?? someone enlighten me.
derrick452 is offline   Reply With Quote
Old 09-24-2007, 09:03 PM   #7
punch
punch's Avatar
the labour is removing the plastic trim ( 90% of it) around doors, floor boards, seats, kick panels..
then removing the front seats,
then the back seat
then the center console
then the carpet
then cutting the sound deadener to fit
then applying it, rolling it out
then re-installing the carpet, seats, plastic trim..
yeah peice of cake!
out of respect for nutzoid, I changed my avatar.
Old 09-24-2007, 09:05 PM   #8
punch
punch's Avatar
now for the roof, removing the trim around the a, b, c pillars (watch for those air bags), removing the dome light, removing the head liner..
again pretty simple should take maybe 1/2 hr (joke)
Old 09-24-2007, 11:00 PM   #9
How does RAAMmat compare with Dynomat in terms of (1) weight (Dynomat is sooo heavy) and (2) sound deadening performance and (3) price?
Old 09-25-2007, 01:09 AM   #10
WolfWings
WolfWings's Avatar
First off, again, the $300-500 price was for just the floor, the most labor-intensive part if you can't afford to have the car down for any length of time. Done in a single day, in around 6 hours between two guys.
As for why not the roof? I can come back and do that later if I need to. It's in the same category as the doors, you can do it in steps without disabling the vehicle while it's in progress.
And RAAMmat is basically two-thirds as good as Dynamat Extreme with one layer, noticably better with two layers, each layer is thinner, and it only costs about $100 for a 62.5 square-foot roll of the stuff. So less than a fifth of the price of Dynamat Extreme by the square foot, barely a third the price if you double up everywhere. RAAMmat takes the "two layers where you need it, one layer where you don't" approach. And heavy is good actually.
And doing the roof is more an issue of that being where the most heat builds up, so if your soundproofing will fail and sag, that'll be where. Another reason I'm waiting to see if I need to bother. :-)
Who has installed Megan Coilovers? Thirty-Nine Wheels, Tires and Suspension Forum sponsored by The Tire Rack 103 03-01-2010 06:50 AM
Installed the Tanabe Strut bar but had to remove my ground wire kit.. vacantj Wheels, Tires and Suspension Forum sponsored by The Tire Rack 6 10-01-2007 01:56 PM
Which options are dealer installed? grampi New YARIS Purchase Forum 4 07-30-2007 01:23 AM
System is installed! Venom In Car Entertainment + Electronics (audio / video / alarm) 14 01-28-2007 06:06 PM
Tanabe NF210's installed...got a question though Terrorize Wheels, Tires and Suspension Forum sponsored by The Tire Rack 32 09-29-2006 07:45 AM
