Old 09-26-2007, 09:14 AM   #1
best way to...?
whats the best way to change my headlight bulbs? is there enough room to slip the bulb in and out w/o taking anything apart? it looks REAL tight...
anyone who has swapped bulbs have any comments/suggestions?
Old 09-26-2007, 09:55 AM   #2
slvryaris
slvryaris's Avatar
Drives: 2007 Yaris Sedan S
I have read posts from people saying its not hard at all to take the front piece off. Here is a link and one heck of a source thanks to Thomas aka Etimago.
http://www.etimago.com/yaris/repairmanual/
Its under lighting and page LI-95 or 97 in your PDF.
Old 09-26-2007, 03:23 PM   #3
tsportman
tsportman's Avatar
Drives: Yaris 1.8 TS
If you have a hatchback, it shouldn't be hard at all !
I changed my two headlamp bulbs (in my case H4, but other types have the same fitting), turn signals and 5w bulbs within 30 mins. !
All you need to do is unplug the connector, slide off the rubber boot and
undo the clips that holds the bulb in place.
The rest of the lamps go out the same way , but don't have a rubber boot.
Only downside is the limited space behind each headlamp, so you have to be a little persistent !
Anyway, you don't have to take the bumper off, or even loosen it.
tsportman is offline   Reply With Quote
Old 09-26-2007, 03:36 PM   #4
03Z33
03Z33's Avatar
Drives: TCR10
tsportman is correct, you can get to it without removing the bumper of headlights but on the US drivers side it is VERY tight, you may want to find someone with small hands to help.
03Z33 is offline   Reply With Quote
Old 09-26-2007, 03:41 PM   #5
duly noted....best get the wife!
how do you beat traffic in NYC? Blenjar NY / NJ/ CT / PA 6 06-23-2007 10:29 PM
