Old 10-19-2008, 05:07 PM   #1
Jsword
what up foo
Jsword's Avatar
Drives: '07 blk LB
LED ignition light
I was gonna hook it up yesterday using the DIY but then...you know
can anyone who installed it tell me where the red wire goes? the black is just a ground right?
Jsword is offline   Reply With Quote
Old 10-19-2008, 05:59 PM   #2
1NZYaris1
1NZYaris1's Avatar
Depends on when you want it to come on,
most people wire it into the courtesy light above your head .
So when you unlock your car it turns on .
Old 10-19-2008, 06:08 PM   #3
||)) (o) ||\||
- Donnie Demonic -
||)) (o) ||\||'s Avatar
Drives: '07 Yaris Sedan Sport
Whenever I do mine I am tapping into the parking light relay. I figure the most useful time to have it on is when its dark out.
||)) (o) ||\|| is offline   Reply With Quote
Old 10-20-2008, 10:20 AM   #4
bikegerm
bikegerm's Avatar
Drives: 2007 Meteor LB
Hey everyone.... I'll take a couple of pics on the wiring of the ignition light and post it for ya'll. I won't have pics of the physical install of the light around the ignition switch with the steering column cracked open but I'll give you some notes about it.
As for the wiring, I'll show pics of how mine is wired. It comes on when the doors are opened along with the dome light. Mine also "times out" with the dome light after the door is shut.
I'll take these pics sometime today or tomorrow. I hope it will help.
Later...
Bikegerm
... yet to be re-established..
bikegerm is offline   Reply With Quote
Old 10-20-2008, 11:04 AM   #5
TinyGiant
Tiny Giant Clothing
TinyGiant's Avatar
Later...
Bikegerm
i would love to know where to tap in for that so can start wiring some more curtesy lights.. floor, glove boxes.. etc
Old 10-20-2008, 11:43 AM   #6
Stoln
Drives: 2007 5 Door Hatch
Do these come in amber as I do want to get this but do not want to change the led?
Stoln is offline   Reply With Quote
Old 10-20-2008, 11:43 AM   #7
||)) (o) ||\||
- Donnie Demonic -
Its the pink wire Tiny Giant
Old 10-20-2008, 02:41 PM   #8
Stoln they come in blue and white, I only got blue this time.
Old 10-20-2008, 03:27 PM   #9
bikegerm
bikegerm's Avatar
From the picture above I can tell you how to wire your ignition light. Pull the dome light connector Donnie has pointed to. It's a 6 pin connector. You need to splice your black ground wire to the pink wire which is off of pin 2, and splice your red power cable to the blue wire which is off of pin 5.
When it is wired here, your ignition light will come on when you open your car door. It will then shut off with the dome light when it times out or when you start your car. When you shut your car off, the ignition light comes on, then times off with the dome light.
This is where I wired mine. As for the physical installation of the light. It's preety easy. Just remove the two phillips head screws behind the steering wheel. There's one on the left and one on the right. You'll need to spin the steering wheel to get to each screw. Pop the plastic covers loose. I dremmeled the opening around the ignition switch slightly on both the bottom and top covers. This helped the fit once the plastic light is placed around the ignition switch. I also put a small black shroud around my light so it would reduce the bleed of the light inside the column, through the side column seams.
I hope this helped. Sorry I don't have any pictures. I installed mine two weeks ago based on a previous DIY.
Randy LeRoy
www.airshowmastering.com
randy@airshowmastering.com
Old 10-20-2008, 03:37 PM   #10
Saggio
Top Notch!
Saggio's Avatar
Drives: 2008
I wanna see this completed. Post pics when your done.
Saggio is offline   Reply With Quote
Old 10-20-2008, 04:29 PM   #11
RagnaCaT
HacKers WanTed!
RagnaCaT's Avatar
Drives: Yaris S HB & Yaris S SD
Garm as soon as you get white please, but please invoice me!
RagnaCaT is offline   Reply With Quote
Old 10-20-2008, 07:03 PM   #12
TinyGiant
Tiny Giant Clothing
TinyGiant's Avatar
what is the power supplied at the dome light circuit ?
Old 10-20-2008, 08:28 PM   #13
bikegerm
bikegerm's Avatar
Hey Tiny. Do you mean in volts? When I opened the door I think it was around 12 volts. I guess I could measure it again. My memory sucks !! This install was 2 weeks ago. Here's a couple of pics. You'll see by the close up, I still need to "trim" my light leakage.
Randy LeRoy
Old 10-20-2008, 08:34 PM   #14
TinyGiant
Tiny Giant Clothing
TinyGiant's Avatar
yeah in volts.. didnt know if it ran on 12 or if it was brought down a little
Old 10-20-2008, 08:42 PM   #15
Klink10
Klink10's Avatar
Germ.....having never done or seen this....are those pins you refer to numbered so that you can see the the numbering or are you going off a diagram?
Old 10-20-2008, 09:29 PM   #16
bikegerm
bikegerm's Avatar
And I remember it being a little under 12 volts. Here's a pin out of the connector.
http://www.etimago.com/yaris/repairmanual/Lighting.pdf / Page LI-19 . Connector 4K
Randy LeRoy
Old 10-20-2008, 10:26 PM   #17
sanityassassinv2
The poison in your poison
sanityassassinv2's Avatar
Drives: 2008 Black Liftback MT
If you still have some at the end of the week, I will be ordering! Thanks for getting us cool stuff!
sanityassassinv2 is offline   Reply With Quote
Old 10-21-2008, 05:54 PM   #18
Saggio
Top Notch!
Saggio's Avatar
Drives: 2008
Looks kickass!
Bulb Replacement Guide (led Sizes) theFEVA Cosmetic Modifications (Exterior/Interior) 113 02-28-2017 12:02 PM
LED Tag Light? Kaeon Cosmetic Modifications (Exterior/Interior) 10 08-09-2010 01:42 AM
LED tail light question Julz Cosmetic Modifications (Exterior/Interior) 4 06-19-2009 09:25 AM
