Old 10-20-2008, 11:47 AM   #1
DanQ
DanQ's Avatar
Drives: 08 Yaris LB
DIY Keyless Entry
I looked through the Yarisworld site when I joined and couldn't find all of the info I needed to add a keyless entry system to a Yaris with power windows and door locks, so I created my own web site.
Details to install a Valet 712T in an 08 varis LB. This should work for sedans as well. You can get the unit off the web for ~$40. Do the install yourself and save $50.
Let me know if this works for you.
Good Luck
Dan
DanQ is offline   Reply With Quote
Old 10-20-2008, 11:54 AM   #2
DanQ
DanQ's Avatar
Drives: 08 Yaris LB
Factory Repair manual
I found this factory repair manual (supplied by etimago) useful for the finding the right wires in the harness and connector locations. This may be useful to you if you are doing an install of a full alarm system or remote start.
Old 10-20-2008, 12:01 PM   #3
TinyGiant
Tiny Giant Clothing
TinyGiant's Avatar
the local car audio wanted $150 for the keyless system they have to sale installed... i think its probably a much better system.. but still...
Old 10-20-2008, 12:40 PM   #4
TheRealEnth
Beast
TheRealEnth's Avatar
Drives: 2007 Blz Blu LB
This is still a pretty good addition that should be added to the Yaris DIY manual
Its a Chao!!!
Old 10-20-2008, 01:39 PM   #5
Bob_VT
Bob_VT's Avatar
Drives: 08 Yaris LB
I used this diagram and instructions when I got the same keyless entry.
This is useful!
Old 10-20-2008, 01:47 PM   #6
aca72
aca72's Avatar
Drives: '07 Yaris S Sedan M5
Also check Best Buy and Circuit City.
aca72 is offline   Reply With Quote
Old 10-24-2008, 04:24 PM   #7
lita_g
lita_g's Avatar
Drives: 2008 Yaris HB
Dan:
I have a question. I had the dealership install a remote keyless system on my 08 yaris LB, and well, it hasn't been a good experience. Anyway, the problem is they installed some aftermarket system, which when I lock the doors using the button on the door of the car, well, it won't unlock with the remote keyfob, I was wondering if you have the same problem with the unit you have (meaning it's a problem with the car), or does it always unlock without considering how the doors were locked?
I would really appreciate if you could confirm that for me, thanks!!!!
lita_g is offline   Reply With Quote
Old 10-27-2008, 03:28 PM   #8
DanQ
DanQ's Avatar
Drives: 08 Yaris LB
Originally Posted by lita_g View Post
Dan:
Mine works similar to what you describe. If you lock manually, the remote unlock doesn't work. You have to unlock manually and then the remote lock will lock and unlock again. It might be a security feature, if you manually lock yourself in the car you are protected from someone entering with a remote unlock. To be honest, I never manually lock the doors. As I walk away from the car, I lock them with the remote...
DanQ's DIY Keyless Entry
Old 10-28-2008, 01:33 PM   #9
b_hickman11
Drives: 08 Sedan
yea if you like getting raped......
Old 11-09-2008, 08:46 PM   #10
CaptainYaris
Drives: 2007 Toyota Yaris S
Wonderful walkthrough. Took it step-by-step on my 4 door and it worked perfectly. got the same system from Circuit City on sale. Not a bad upgrade for $50
CaptainYaris is offline   Reply With Quote
Old 11-09-2008, 11:23 PM   #11
Revsson
I ended up getting a car w/keyless entry, but had seen this writeup before the hack.
http://home.comcast.net/~dquicker1/s...ess_Entry_DIY/
Just wanted to say that it is a great webpage that you made.
The photos really help to understand things.
Old 11-10-2008, 12:20 AM   #12
yarstar
Drives: 2008 Absolute Red HB
Just wanted to give props to DanQ. I used his DIY this summer and got one off Ebay for $35. Major easy. I even mis-wired it the first time and DanQ quickly answered my email and helped me get it straightened out. It's been working great ever since.
I too have the problem with the manual door locks conflicting with the remote. I just use the remote all the time and its never really a problem. The door switches still work if needed.
DanQ really made a $200+ upgrade down right affordable. Really good DIY. Thanks again Dan.
AEM CAI, NST Pulleys/SSK, WR 4-2-1 Header, TRD axelback, R1 Concept Rotors, TRD Sway Bar, Nitto Rear Strut Bar, Cusco GT-Zero Coilovers, 1ZZ-FE 1.8L TB
yarstar is offline   Reply With Quote
Old 11-10-2008, 12:44 AM   #13
Check out my post on this thread for the correction to the door switch issue:
http://www.yarisworld.com/forums/sho...?t=9827&page=2
DanQ, you might want to try it as well and then update your DIY.
I am working on a DIY for Remote Start / Keyless entry for 07-09 with and without engine immobilizer.
Old 11-10-2008, 06:19 PM   #14
b_hickman11
Drives: 08 Sedan
Hopefully nothings goes wrong with. Circuit City filed for bankruptcy today and are shutting down a lot of their stores. My local store is suppose to be shutting down by Jan 1.
Old 11-12-2008, 02:48 PM   #15
CaptainYaris
Looks like i need to go back and tap into the green wire. another problem i was having is that when i turn on the car, all the doors go through the "unlock" cycle. hopefully this issue will be remedied by this as well.
Old 11-12-2008, 02:56 PM   #16
The unlock on start issue is probably a "programming option" for the keyless entry.
Old 11-13-2008, 09:28 AM   #17
CaptainYaris
I've looked through the programming guide and i think i'd have to disable the "lock on start" to disable the quick unlock on start. Its really not that big of a deal.
But the switch to the Green wire worked wonderfully, although i have to say the Valet system is a little slow to respond between the first press and the 2nd press, you have to wait for the parking lights to stop flashing before you press the button a 2nd time.
Old 11-13-2008, 09:31 AM   #18
Does the valet have a mode for double pulse of the unlock wire? My UltraStart did and it makes life a lot easier than having to press the remote twice.
keyless entry? / security? mem In Car Entertainment + Electronics (audio / video / alarm) 8 10-22-2008 02:29 AM
Keyless Entry BLKYRSSDN In Car Entertainment + Electronics (audio / video / alarm) 44 09-16-2007 11:27 PM
Aftermarket Keyless Entry - How does it affect the Warranty? aerock19 In Car Entertainment + Electronics (audio / video / alarm) 7 09-07-2007 03:11 PM
I want keyless entry!!! Lillydot General Yaris / Vitz Discussion 7 03-20-2007 11:46 PM
DIY KEYLESS ENTRY on Power Liftback? TC-LIFTBACK DIY / Maintenance / Service 0 08-23-2006 10:57 AM
