Old 10-22-2008, 11:46 AM   #1
Callisto
Callisto's Avatar
Drives: '08 Hatch
What kind of add-a-fuse/circuit?
I know there was a thread that answered this question before the hacking, and I was just planning on using that one for reference.
Now, I have to ask.
Since the Yaris uses low-profile fuses, do we need to use a special version of this little device, or do you just use the mini version and let the blades stick out a little bit?
A link to the specific piece would be helpful.
Thanks in advance.
Sorry, wrong forum, thought I was in the DIY..
Callisto is offline   Reply With Quote
Old 10-22-2008, 08:41 PM   #2
Rotorheader
Drives: 07 Yaris Hatchback
We have a couple different size fuses in several fuse boxes. Determine which fuse you want to tap into, then take that fuse with you to an auto parts store. Can't go wrong that way.
Rotorheader is offline   Reply With Quote
Old 10-22-2008, 09:34 PM   #3
PHXDEMON
PHXDEMON's Avatar
Drives: 2007 Red Liftback
Just use the normal mini size ones.
Old 10-23-2008, 04:02 AM   #4
IsLNdbOi
IsLNdbOi's Avatar
How do you use these open slots in the fuse box? Say I wanted a switched power source for an accessory like an audio source switcher for my HU, which open slot(s) in the fuse box could I plug it into? Is there a special plug I need to buy to attach to the accessory's power wire so I can plug it into an open slot in the fuse box?
The fuse box I'm referring to is the one underneath / behind the pocket in front of the driver's left knee / leg.
Old 10-25-2008, 10:48 PM   #5
IsLNdbOi
IsLNdbOi's Avatar
Anyone?
Old 10-26-2008, 12:32 AM   #6
Jerkratt
Jerkratt's Avatar
i hooked up my a pillar gauges and used the mini add a fuse with the cig lighter.. ill take pictures of it tomorrow.. all rainy and dark now
"It hurts more when its wet"
Old 10-26-2008, 12:35 AM   #7
IsLNdbOi
IsLNdbOi's Avatar
Cool. Looking forward to the pics..
Old 10-27-2008, 12:15 PM   #8
sanityassassinv2
The poison in your poison
sanityassassinv2's Avatar
Drives: 2008 Black Liftback MT
You just use the standard mini add-a-fuse. If you want a power source that switches on and off with the ignition, pull your accessory fuse and put the add-a-fuse in it's place. You should be able to identify the accessory fuse by looking on your fuse box cover for the fuse labeled "ACC" (or something along those lines.) The add-a-fuse holder has two fuse receptacles: one for the original curcuit and one for your new curcuit.
There is one wire that comes off the add a fuse circuit--you may connect that to the + lead of your accessory however you see fit (crimp connector, butt splice connector, soldered/taped connection, etc.) For the negative connection, run your - wire from the accessory to chassis ground. On my car (08 Liftback), there is a good ground connection under the kick panel in front of the drivers door and just below the fuse box.
When I get home today, i will try to snap some pix for you.
sanityassassinv2 is offline   Reply With Quote
Old 10-27-2008, 05:13 PM   #9
IsLNdbOi
IsLNdbOi's Avatar
Thanks! Looking forward to the pics..
Old 10-27-2008, 06:10 PM   #10
sanityassassinv2
Ok, so here is the fuse box and the ground point. You will need the add-a-fuse, and two standard mini fuses.
Old 10-27-2008, 06:15 PM   #11
IsLNdbOi
IsLNdbOi's Avatar
Thanks for the pics! So, the fuse box's lid / cover has a diagram that shows which fuse slot in the fuse box is switched or unswitched with the ignition? We can ue an add-a-fuse/circuit with any fuse in that fuse box?
Old 10-27-2008, 07:00 PM   #12
sanityassassinv2
I think the current limitation on the Add-A-Fuse is 10 amps (possibly more but I don't remember)--so use you can it anywhere there is a 10A fuse or less--on my car the ACC fuse is a 7.5A. The diagram on the cover doesn't say what is switched or not, but the ACC should be...you can verify this with a multi-meter or after you hook everything up.
Old 10-27-2008, 07:02 PM   #13
Jerkratt
Jerkratt's Avatar
u beat me to the pics but il post mine up as well for reffeance
Old 10-27-2008, 07:09 PM   #14
IsLNdbOi
IsLNdbOi's Avatar
Thanks Jerkratt! The more pics. the better.
Old 10-28-2008, 01:50 AM   #15
Jerkratt
Jerkratt's Avatar
sorry its raining outside so i could not climb into the car and get nice shots
Did you guys (Moderators) stop us from add pictures to Our garage? pp.sweet Off-topic / Other Cars / Everything else Discussions 11 09-26-2007 12:32 PM
Help sign this petition! Add the Yaris and other small cars to Forza 2 eTiMaGo Off-topic / Other Cars / Everything else Discussions 24 08-10-2007 12:57 PM
16" wheels and bigger: What kind of mileage ? nurburgring Wheels, Tires and Suspension Forum sponsored by The Tire Rack 4 07-31-2007 10:53 AM
Vitz Rs turbo vs U.S. Yaris add turbo? weaponrcamry Performance Modifications 18 08-09-2006 08:45 PM
Should I add remote key less entry? Options YotaYarisUSA General Yaris / Vitz Discussion 13 05-02-2006 05:06 PM
