Old 10-23-2008, 08:58 AM   #1
Smokey159
Drives: Yaris Liftback
Cutting bumpstops on Tein springs...
I bought a set of used Tein springs for my liftback. But I don't have the instructions and was wondering if anyone here has installed them and knows how much to cut the bumpstops.
Thanks in advance.
Smokey159 is offline   Reply With Quote
Old 10-23-2008, 09:10 AM   #2
ddongbap
I swear there has been 4 posts about this in just the last week. Cut them around 2 inches.
Old 10-23-2008, 04:56 PM   #3
PetersRedYaris
PetersRedYaris's Avatar
Drives: 2005 Scion xB
This is the max you can cut them. Any more and you risk bottoming out the strut and causing damage to it. It is recommended that you trim off the same amount as the drop. So, 2 inch drop, cut 2 inches off. 1.5 inch drop, cut 1.5 inches off. Just don't go past what the picture shows...
See here-
http://www.yarisworld.com/forums/sho...503#post154503
Old 10-23-2008, 08:15 PM   #4
FunctionSpec
Super Newbie
FunctionSpec's Avatar
Drives: 2007 Yaris Liftback White
Cut off about ~25MM or 1inch. You really don't need to cut off the same amount as the drop. Lowering springs are stiffer then stock so the shocks travel through shorter cycles which means they don't need that much travel between the bumpstop and shock body. 1 inch of travel is sufficient for a comfortable ride.
If you cut it shorter then that like in the picture, you run the risk of rubbing in the front. Too much upward travel will allow the wheel to travel to far up into the wheel well. Also less bumpstop means less absorption for hard bumps and dips.
FunctionSpec is offline   Reply With Quote
Old 10-24-2008, 06:24 AM   #5
thatboyjer
thatboyjer's Avatar
Drives: 5spd 2007 Yaris LB
actually you want to cut it exactly where the picture shows. I have DF210s and i've had 17"s and 15"s and bumpstops at the length petersredyaris posted. I've yet to actually experience some rubbing
see post http://www.yarisworld.com/forums/showthread.php?t=9831
99.9% of what goes on in my mind at work/school/home
[Debadged] [Tanabe DF210] [Limo Tint][17" Fondmetal Wheels] [Pioneer HU]
--:: Wishlist, PM me ::--
[SSK (WTB)] [Black Sand Pearl Eyelids (WTB)]
thatboyjer is offline   Reply With Quote
Old 10-24-2008, 09:42 AM   #6
PetersRedYaris
I would actually recommend leaving about 1/4 inch more that what is shown. This is especially important if you run wheels that have an offset of 38-40mm. To short of bumpstop and you will rub the fender liner because of the extra uptravel. If your offset is 42-45mm, you can cut them as shown and most likely have no rubbing.
FunctionSpec makes a good point too, that suspension travel with stiffer springs will be less. (see above) Just don't go shorter than shown or you can and will ruin your struts.
All this only applies to using drop springs on the OEM front struts. I don't have any knowledge on the TRD struts or others...
Old 10-24-2008, 05:15 PM   #7
ddongbap
I'm sure that running a lower offset would cause rubbing no matter how tall your bump stop is.
Old 10-24-2008, 05:17 PM   #8
natethegreat38
Party like a Barack star
natethegreat38's Avatar
Drives: '08 LB MT
ddongbap-
I'm off topic here, but it was nice meeting you and all the other Yaris peeps the other night...by the way, how many zeros are in a BAJILLION??????
i don't feel like creating another signature, yet. Give it another week...
natethegreat38 is offline   Reply With Quote
Old 10-24-2008, 05:44 PM   #9
ddongbap
Originally Posted by natethegreat38 View Post
ddongbap-
More than what anyone types. Since its progressive, no matter how many zeros you put down, there'll be about 14 more than you.
Old 10-27-2008, 10:50 AM   #10
natethegreat38
Drives: '08 LB MT
Ha!
Old 10-27-2008, 03:37 PM   #11
MUSKOKA800
MUSKOKA800's Avatar
Or buy the FatCatMotorsports bumpstop kit with spacers and have a bottoming free ride.
http://fatcatmotorsports.com/FCMstops_Yaris.htm
Works like a charm in my TRD suspended sedan.
Old 10-28-2008, 11:57 AM   #12
Smokey159
Has anyone actually installed Tein S-Techs and knows what the instructions say?
Old 10-28-2008, 09:52 PM   #13
PetersRedYaris
Someone here know the answer to this... I read it awhile back, but can't remember. According to Tein, your supposed to cut them, but how much???
Old 10-28-2008, 11:07 PM   #14
battleversiontc
battleversiontc's Avatar
Drives: 08 vip yaris
i normally just cut them in half
08 junction produce belta almost done and ready for paint
06 junction produce tc 604 bhp 445tq ddriven still trying for 700+hp
90 crx sir ls vtec turbo 755 hp
mecp masters certified
battleversiontc is offline   Reply With Quote
Old 10-30-2008, 09:35 AM   #15
Smokey159
SOLUTION:
OK, I got the official word from Tein on this issue.
The S-Techs require that 1.4 inches be cut off the end using their "A" cut method. They have 4 different ways to cut bumpstops, the different methods can be found in the tech section of their website.
Can't believe I'm modding a Yaris, I must really miss my STi...
Old 10-30-2008, 12:27 PM   #16
marcus
toyota
marcus's Avatar
Drives: 2007 Yaris RS Blazed
im curious what happen if you dont cut the bump stop on the trd i think its 1.2-1.5 drop..
Tein Lowering Springs SKC10-AUBOO c-one yaris Wheels, Tires and Suspension Forum sponsored by The Tire Rack 5 09-10-2007 01:58 AM
Tein Springs nickhjort Wheels, Tires and Suspension Forum sponsored by The Tire Rack 8 08-15-2007 12:33 AM
Springs - Tanabe DF210 or Tein S Tech andylai2k Wheels, Tires and Suspension Forum sponsored by The Tire Rack 9 06-10-2007 09:22 PM
Tein Basic Damper Coliey's Vs. Tein S. Tech Springs ToTo Wheels, Tires and Suspension Forum sponsored by The Tire Rack 35 05-07-2007 05:08 PM
TEIN S-Tech Springs *NOW AVAILABLE* EnduroMTS Sponsors Classifieds Area 1 10-12-2006 02:08 PM
