Old 10-23-2008, 11:59 AM   #1
Aothachos
Drives: 2008 Yaris Sedan
Send a message via AIM to Aothachos Send a message via Yahoo to Aothachos
pulleys are all on, but....
okay i got my pulleys just installed today, the rest of the water pump and altenator pulley, now after it was done the guy said that my fuse blew out for the altenator located near the battery terminal, he said that when he put it on, turned on the car the fuse blew and said "wow it spins that much faster?". he is finding out how much the part is from toyota and telling me to go buy it, he sodered it for now but he doesn't now how long it would run like that.
i never heard of this happen from any of you guys when you put your pulleys on, you guys think this guy is busting my balls?
possibly a reply from NST with some suggestions, etc would help please, thanks
Aothachos is offline   Reply With Quote
Old 10-23-2008, 12:44 PM   #2
PETERPOOP
PETERPOOP's Avatar
Drives: 08 white liftback
I put all three on and that didn't happen to me. I have no clue. Sorry.
Old 10-23-2008, 01:10 PM   #3
ROCKLAND TOYOTA
TRIM HUNTER
ROCKLAND TOYOTA's Avatar
alternator fuse???? if you tell me position of fuse under hood i can tell you WHAT IT IS.....
Old 10-23-2008, 01:26 PM   #4
it's an underdrive pulley kit, right? That's supposed to make your alternator spin slower than before, so it sounds really odd..
Old 10-23-2008, 02:59 PM   #5
Nexus1155
Bathroom + Laptop = <3
Drives: Audi
i think the guy is screwing with you IMHO.... I also do not know what he would have soldered... the circuit inside the fuse or is it a relay? ............doubtttt it
Old 10-23-2008, 03:23 PM   #6
None of the pulleys make anything spin faster. I don't think you could tell just by looking even if they did.
And, he could easily check the voltage the alternator is producing. Did he measure that before making his comments?
Clearly the guy doesn't know what "underdrive" means.
Yikes.
Old 10-23-2008, 03:53 PM   #7
Nexus1155
Drives: Audi
that would be funny to watch and see the guy trying to though!!
Old 10-23-2008, 04:48 PM   #8
PetersRedYaris
PetersRedYaris's Avatar
Drives: 2005 Scion xB
Soldered a fuse together for a temperary fix? Don't take your car back there ever again...
Old 10-23-2008, 06:23 PM   #9
1NZYaris1
1NZYaris1's Avatar
Sounds to me, like he had a problem getting the old alt pullie off ,
and stuck a screw driver into it to stop it turnning, damaging the coil.
Thats just my opinion for what its worth.
if you replace the fuse and it blows again then thats your problem.
send him the bill.
Old 10-23-2008, 06:44 PM   #10
Black Yaris
der Zeck
Black Yaris's Avatar
$100 says the guy did not disconnect the battery before pulling the alternator
Old 10-23-2008, 06:50 PM   #11
Aothachos
yea this guy is so dumb lol when i left he said if u have any good parts you wanna install i will be more than happy to do it for you, and funny part is i just told him a new crank pulley was on there already i didn't mention it was underdrive hes just trying to pull money out of my a$$ he said 60$ to install then they changed it to 145$ because 2 of my bolts were stripped i ordered one bolt and they replaced the other one, so yea they are BS and it only took about 1 hour to do, so where did the labor cost come out of that when they charge like 75$ for labor only i stil have to pay him off tomorrow when i get my check but when he asks me about the fuse ima look at him and say "do you think im fukin stupid" lol *excuse my language*
Old 10-23-2008, 06:53 PM   #12
Aothachos
oh yea and he said the fuse is located under the red cover battery terminal, theres 2 fuses and the one on the right blew, im trying to think how the hell did that happen and yea yatta yatta yatta
Old 10-23-2008, 07:18 PM   #13
Nexus1155
Drives: Audi
i hooked up an audio system in the yaris and had to hook up the power line to the "red terminal" and i honestly never noticed a fuse there... maybe just me, or maybe hes just an idiot... and how are your bolts stripped on a new car.... hes probably the as that didnt use the correct tool and stripped them himself...
tell him you would like it reduced to an hour and only pay the original amount specified because the other problems were his own fault and tell him to fix the "fuse" problem too..
PLEASE DON'T LET THIS SHADY MECHANIC SCREW YOU!!!
Old 10-23-2008, 09:55 PM   #14
battleversiontc
battleversiontc's Avatar
Drives: 08 vip yaris
i agree thats kinda messed up and what fuse there is no fuse on the battery terminal ? i think you should tell him to show you and take a picture cause that guy has a a$$ for a certification instead of a ASE certificate
08 junction produce belta almost done and ready for paint
06 junction produce tc 604 bhp 445tq ddriven still trying for 700+hp
90 crx sir ls vtec turbo 755 hp
mecp masters certified
battleversiontc is offline   Reply With Quote
Old 10-23-2008, 11:29 PM   #15
dacourier
dacourier's Avatar
Drives: Black Sand Lift Back
I have these fuses on my Xterra but I don't recall having them on my Yaris. What year is your Yaris? The fuses on the Xterra at least one of them is for the power coming from the alternator. The others go to your main power box for the car. I am positive this guy didn't disconnect the battery before the install. You should be able to get the fuse which is more than likely a 60 to 100 amp fuse from AutoZone or any auto parts store and replace it your self. Just look at it closely and see what size it is. He probably just popped the clear cap on the top of the fuse and soldered it. I wouldn't drive it for to long like that because you never know if or how much damage the guy could have caused! Good luck
Clinging to my guns and religion down here in the south. Come and take them!
dacourier is offline   Reply With Quote
Old 10-24-2008, 12:46 AM   #16
blacksandiegovitz
Your mom goes to college
blacksandiegovitz's Avatar
Drives: 08 Vitz
^^ What he said . dumb sob touched a screwdriver or wrench to the alternator and grounded it out , blowing the fuse . Now he is tring to charge you for his mistake , No dice bro , call that douche on his shit man .
Old 10-24-2008, 11:36 PM   #17
Aothachos
Yeah I am going to say to him all that crap and prove him wrong and also request a refund also for his company to pay for any damage and repairs that need to be done to my car because of him, and toyota will fix it not him.
NST Pulleys hatchbackkid82 Performance Modifications 15 09-29-2007 08:04 PM
ait resistor mod pigpenracing Performance Modifications 24 08-25-2007 11:14 AM
ZPIracing Yaris Pulley ZPIracing Performance Modifications 19 05-15-2007 01:51 PM
