Old 10-23-2008, 07:00 PM   #1
sketch182
sketch182's Avatar
Drives: 2008 Silver Hatchback
Transmission revving to 3,500 when cold
When I drive my car after initial startup, my transmission won't change until it reaches about 3,500 rpm. Once I have driven about 2km/1m, the gear changes are normal at much lower rpm.
I s this an expected warm up period, or is it a problem? I haven't been for my first service yet, so the car is fairly new.
sketch182 is offline   Reply With Quote
Old 10-23-2008, 07:06 PM   #2
TinyGiant
Tiny Giant Clothing
TinyGiant's Avatar
its the warm up period .. gets the engine up to temp.. it wont change gears until you go over 30mph
Old 10-23-2008, 07:10 PM   #3
ECHOKnight2000
Small Car Lover
ECHOKnight2000's Avatar
Drives: A Super Car
Yes this is "normal." It has to do with emissions. When your car is cold it emits more emissions, than when its warm. The transmission won't go into the overdrive gears until it reaches a certain temp.
Just don't race it (when cold) and you should be fine. My car does this too. I think most Toyota's do. I don't know about other car makes.
You may look good on the beach but in reality you're a pompus, egotistical jerk. "I was never on the beach with you..."and you never will.
ECHOKnight2000 is offline   Reply With Quote
Old 10-23-2008, 07:16 PM   #4
sketch182
sketch182's Avatar
Thanks for the responses. At least I don't have to take my car in for an early service.
My car does stay at high revs even to 100 kph, but I am seconds from a major highway so it is still a bit cold. Apparently this is normal though. My 1995 Corolla and 2006 Rav4 don't have the same feature.
Old 10-24-2008, 09:52 AM   #5
SilverGlow
Drives: 2007 Yaris Hatchback
All late model cars do this. The late shifting forces higher RPM's which cause the catelytic converter to heat up to full operational temperature faster. It will not be effective until that happens. The car will shift normal once the water temp reaches 130 degress F. Until then, DON'T rev past 2,500 and just tippy-toe and drive slow...let the oil wake up and circulate around....once the "cool" light on the dash goes off, the temp is 130 or great, then you can start to drive a little more aggressive.
SilverGlow is offline   Reply With Quote
Reluctant upshift to 3rd while cold (auto trans) pauljk General Yaris / Vitz Discussion 40 01-22-2011 06:04 AM
Urgent! How to use auto transmission? hans_fh General Yaris / Vitz Discussion 55 04-16-2010 01:45 PM
Want opinions automatic vs. manual transmission anik New YARIS Purchase Forum 84 07-10-2007 04:25 PM
Transmission needs to warm up????? bojim General Yaris / Vitz Discussion 9 01-01-2007 05:49 PM
