Old 07-20-2006, 11:02 AM   #1
Idjiit
5 Stars, Bitches
Drives: Prius, Silver Yaris Liftback
Bi-Level Storage Mod Complete...
I'd mentioned in the thread where I discussed taking out the backseats that I was going to be putting in storage for my photo gear. Well, here it is, complete.
Unfortunately I didn't document the whole process because, well... it took forever and I can't imagine anyone else following the same steps. But the basics is that it's constructed of 3/4" aluminum square stock, various brackets, 1/4 plywood and a shitload of screws. It has been covered in thin indoor/outdoor carpet. All in all, it's quite light. I don't think I'm over stock weight at this point, and it's possible I'm a bit under. The non-carpeted version of this went on a 12hr trip and the car got 41mpg, so it certainly isn't hampering anything. So far no squeaks/rattles, but I suspect that will change with time.
Bottom portion - about 1 1/2 inches off the bottom of the car frame to avoid hitting the gas tank "bubble" and the spare-tire flange:
3/4 view
Note the carriage bolts in the channels - used for locking in the top section, which will be shown later:
Horizontal view, note the dog grate and the plexiglass panels on the edges (so I can actually see):
From the passenger door
Hitch pins at the top, which can be pulled out...
...so the grate can come forward so you can fit the tables in (more on that later). I may replace the bolts at the bottom with hitchpins as well so you can just remove the whole thing.
First of two table slid in - this is aluminum as well, with a formica top. The table locks to the subframe through 4 "keyholes". This isn't so much for security per se, but to keep things from rattling around and to protect the dogs from getting crushed by the gear in a rollover crash.
Second table and the "locking portion" in place:
The "locking" piece. Since the two tables slide and lock in opposite directions (away from the middle) the locking portion simply prevents them from backing out of their "locked" positions:
Since the tables will stay in most of the time, the grate is "hinged" right now so if I need extra room I can just lay the grate flat if I need to fit in a 2x4, etc.
The missing link here is one more carpet that goes over everything and velcros down so everything is "hidden" and so the dogs have something comfy to walk around on. They have a ton of room back there, which is great. The only downside is that since the platform is raise, you're looking at your dog's junk about 50% of the time. ;)
Oh, if you're wondering WTF those tables are for, they come out and are used as part of our onsite printing setup:
Idjiit is offline   Reply With Quote
Old 07-20-2006, 12:35 PM   #2
stuffy
stuffy's Avatar
Drives: 06 yaris 5-dr le man
very innovative idjiit, this is the type of mod that i like, something that is suited to an individual's needs, very cool!
stuffy is offline   Reply With Quote
Old 07-20-2006, 02:08 PM   #3
cadence220
Drives: Toyota 4Runner
That's great! The grate looks cool as well. Just the thing I need for my four-leggers. How'd you do that?
cadence220 is offline   Reply With Quote
Old 07-20-2006, 02:13 PM   #4
ChinoCharles
Drives: LB
Bravo man. Great mod, I think everyone could think of a use for that.
Old 07-20-2006, 02:22 PM   #5
heylookitsjames
maintenance of momentum
Drives: 2007 5spd 3dr
Beautifully executed.
heylookitsjames is offline   Reply With Quote
Old 07-20-2006, 03:02 PM   #6
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
a work of art my friend....would prolly work great for kids too
Old 07-20-2006, 03:25 PM   #7
Chris07LB
Chris07LB's Avatar
Drives: Yaris Liftback
+1
Old 07-20-2006, 04:15 PM   #8
ricko
ricko's Avatar
Drives: Copper-Orange Yaris RS
Very clean!!!!!! Congrats on a truly functional mod.
ricko is offline   Reply With Quote
Old 07-20-2006, 04:28 PM   #9
PixieDawn
Drives: Yaris 2007, Eclipse 2000
That looks great are you planning on putting the back seat back in when not in use or is this a perm. change?
PixieDawn is offline   Reply With Quote
Old 07-20-2006, 06:30 PM   #10
Idjiit
5 Stars, Bitches
It's semi-permanent. There haven't been any structural changes to the car, but getting it in there is difficult enough that's it's not something you can just unbolt and take out for the weekend. I originally had that in mind, but the car is so small that to take advantage of all the space I had essentially build it inside the car instead of building it outside and then bringing it in - although some portions were built like that. In the long run it doesn't really matter - we have the Prius if we need to tote around passengers.
Thanks for the compliments, guys!
Old 07-22-2006, 04:39 AM   #11
TRD_Yaris
Yarii Hunter
TRD_Yaris's Avatar
Drives: 2007 Yaris Liftback and S13's
I am VERY IMPRESSED!!!
Thanks for all the help over the years, YarisWorld!!!
TRD_Yaris is offline   Reply With Quote
Old 07-22-2006, 10:44 AM   #12
Chaad32
Chaad32's Avatar
Drives: 2007 Liftback
Good job..
2007 Liftback
Blazing Blue
Cold Weather, Convenience Package, Arm Rest,
Floor mats, Weathertech vent visors
Chaad32 is offline   Reply With Quote
Old 07-24-2006, 03:03 PM   #13
Idjiit
5 Stars, Bitches
I know some of you guys were interested in what we were doing photo-wise so here's some photos of the table setup we're using...
Here's some shots of the setup onsite...
The tables strapped down. All of the gear is out of the Pelicans at this point. The legs seen here all fold up into the tables themselves - very self-contained:
People viewing the Kiosks, my wife helping a couple with photo selection:
The "sidecar" is mainly for the printers and the "print machine" (the other two machines are dedicated Kiosk machines at this point. They have keyboards and mice attached to them facing the customers, and we can use the keyboard/trackpad on the laptops to control them from our side. It works wonderfully. A lot of people have jumped right in and figured out how to use Lightroom, and often times customers will help each other - a testament to the ease of use of Lightroom.
The view from our side:
Old 07-24-2006, 03:33 PM   #14
Chris07LB
Chris07LB's Avatar
Awesome setup you guys have!!
Even cooler, that it all fits inside a LIFTBACK!!!
Old 06-11-2007, 04:05 PM   #15
srivinus
Send a message via Yahoo to srivinus
Where did you get the tables
Hi Idjiit
I am photographer from Charlotte and saw the mods. I just picked up a Yaris because I wanted something with good gas mileage since I do a LOT of city driving and parallel parking. Figured I had a van for the bigger location stuff and the Yaris would be perfect for small location headshots.
I love the mods to the back. I was thinking of doing something similar and had not thought of the bi-level config. Got a question for you. Did you make the tables or did you buy them somewhere?
Sean Rivinus
srivinus is offline   Reply With Quote
Old 06-11-2007, 04:27 PM   #16
PolrWht07
Building my Yaris
PolrWht07's Avatar
Drives: 07 Polar White Yaris Sedan
Very cool. Too bad I can't fit a wrestling ring in my yaris, that'd help with my profession, haha.
All show no go!
PolrWht07 is offline   Reply With Quote
Old 06-11-2007, 09:57 PM   #17
churp
Clean and (dis)Functional
churp's Avatar
Drives: Yaris 2dr--Black Betty
I have to start looking thru the old threads....Idjiit, you're a true craftsman.
____________
Old School Cobble Jockey
churp is offline   Reply With Quote
Old 06-11-2007, 10:07 PM   #18
joey1320
joey1320's Avatar
Drives: Yaris LB
great work man!!!
like it was said before, this is the kind dyi that is suitable to a small portion of the yaris owners, but it shows the different ways the car can make somebody's life better. great!
